Old November 13, 2010, 09:34 AM
Default 3 monitors on linux
I'm looking for a video card to run 3 monitors on linux
not for gaming, just bigger extended desktop
I'm thinking some 5770 or lower
do I need two video cards?
Old November 13, 2010, 09:52 AM
If the monitors are 27" and smaller you only need 1 ati/amd Radeon HD Video card. however if they are 30" monitors you will need multiple video cards.
Old November 13, 2010, 06:43 PM
If he doesn't do any gaming then he'll need 2 cards no matter what.
1 for the dual head and the 2nd for the third monitor.
Old November 13, 2010, 08:30 PM
for some reason, I was under the impression that 5000 series with eyefinity could run 3 monitors without crossfire and not running eyefinity...
Old November 13, 2010, 09:21 PM
Last I checked ATI support for Linux was dismal at best.. You may want to check support for such things.
Old November 13, 2010, 09:27 PM
The OP wants to run 3 monitors in Linux, eyefinity won't work, at least not right now, ATI/AMD promised support with the 10.1 drivers and it hasn't happened. He'll need 2 cards to run 3 monitors the old fashioned way and they don't have to be in crossfire/sli. Probably wouldn't work in crossfire either.
Old November 13, 2010, 11:46 PM
So, if I don't use eyefinity,(doesn't work in Linux), even 5870 eyefinity 6 will only do 2 monitors?
Old November 14, 2010, 11:13 AM
Until ATI/AMD releases the promised drivers at least. Which you shouldn't expect to happen as they were supposed to be the 10.1 drivers from a while back. ATI/AMD has made major strides in terms of Linux drivers the past few years, but they still have a long ways to go to match Nvidia's support.
triple monitors kyle_L Display Units 1 December 26, 2008 10:04 PM
Multi Monitors Infiniti Display Units 1 December 7, 2008 09:55 AM
dual monitors cmac79 Guides & How-to's 27 October 16, 2008 03:36 PM
cables for monitors Tazer-[X] Troubleshooting 9 July 16, 2008 11:08 AM
2 Monitors ih8purple Display Units 3 January 22, 2008 11:09 PM
