Old November 12, 2010, 04:24 PM
Battery's Avatar
Default GTX 580 or 470 sli for 3d vision
I'm trying to decide between an Asus GTX 580 or two MSI Twin Frozr II GTX 470's in sli for 3d vision.
Now my system is.. different. It's based around the Tyan s4985 Thunder n4250qe mother board and houses four Opteron 8356 quadcore cpus, each clocked at 2.3ghz.
So which do you think would be better for 3d vision at 19x12, and (assuming only one cpu to be used) is 2.3ghz going to bottleneck the 470's?
Thanks in advance!!
Gateway P-7811FX:
2.26GHz Intel Core 2 Duo P8400
Nvidia GeForce 9800M GTS
4GB, 1066MHz DDR3
200GB 7,200rpm
Old November 12, 2010, 04:56 PM
rjbarker's Avatar
OC the CPU....sell the single 470 and get 2x 580's (SLi) ;)
Seriously...SLi 470's will provide far better performance than a single 580......BUT (in the future) SLi 580's will kick some serious _ss !! Given the lower temps, lower power consumption, higher performance...the 580's are worth the upgrade.....
NV has a real winner here......yes you can wait n see what ATI has to counter, but the realtiy is, the ATI Card, if it is a better card than the 580 (temps, Power, Xfire Scalability, performance, noise) than it will likely be priced higher and likely a dual GPU Card (good luck with the Drivers).
Classified Ultra SLi "Procyon"
http://i30.photobucket.com/albums/c3...2/DSC02888.jpg
http://i30.photobucket.com/albums/c3...2/DSC02889.jpg
Evga 4.2 Ghz Club....
Old November 12, 2010, 04:57 PM
I think your processor will bottleneck both the 580 and 470 in SLI.
Anyone else for input?
Old November 12, 2010, 05:06 PM
rjbarker's Avatar
He's definitely got to OC it a tad....3.8 Ghz would be good....
Old November 12, 2010, 05:10 PM
Battery's Avatar
With a bios flash and some luck I can push the cpu's to at least 2.5, I can't actually oc the cpu's, but I can use an ancient version of ntune to increase the HyperTransport clock of the mobo (see this), which raises the core clock and memory clock. I can't do any voltage bumps either.
To clarify, I haven't bought any video cards yet and this system has four quadcore processors.
Gateway P-7811FX:
4GB, 1066MHz DDR3
200GB 7,200rpm
Old November 12, 2010, 05:21 PM
im thinking single card, wait till amd replies, at least for some better pricing.
even at 2.5 the cpu will keep you back, although at that resolution it won't matter much.
happy to see them ...folding? :)
Old November 12, 2010, 06:38 PM
rjbarker's Avatar
^^^ Thats right Dan....the OP's got to ge that CPU to at least 3.2 Ghz....or it will be holding back his GPU's.
Old November 12, 2010, 07:57 PM
Delavan's Avatar
So that system with 4 Opterons uses only 1 CPU for games at all?
i5 2500K @ 4.5GHz / NH-U12P / P8P67 DELUXE / 8GB Corsair Vengeance Arctic White 1.35V 1600 / 2 x N560GTX Ti Twin FROZR II OC in SLI (8823 3Dmarks11 P-score)/ Corsair Performance Pro 128GB SSD
Old November 12, 2010, 11:02 PM
Battery's Avatar
It's still a work in progress.. this weekend I'll be moving it from the table it was sprawled over into the haf 932 I just got.
It all depends on how threaded the game is. If it only makes 4 threads then it'll probably only use one cpu, if it can create more than 4 threads then it'll utilize more cpu's and I won't have to worry about a bottleneck.
I was trying to figure out if the dual 470s would bottleneck in a situation where the game only created a max of 4 threads, in which case only one processor would be used.
Then again, most of what I've said is based on assumptions and what I've read online. This is my first multi processor system and may be my first multi graphics card system.
All I was is concise evidence saying 'no, your system won't bottleneck' or 'yes, your system will bottleneck this badly'.
Also, Would folding benefit more from two 470s or one 580?
Gateway P-7811FX:
4GB, 1066MHz DDR3
200GB 7,200rpm
Tags
3d vision , gtx 470 , gtx 580 , quad , sli
Is nVidia GTX 470 a better choice than a ATI Radeon 5850 when used in SLI/Crossfire? kendrab Video Cards 9 November 8, 2010 01:49 PM
Comment Thread for NVIDIA GeForce GTX 470 SLI Review SKYMTL Video Cards 48 April 19, 2010 01:49 PM
