Originally Posted by werty316 Because the HD3870 and HD3850 are electronically and physically different.
Thats like saying why can't you flash an 8800GTS 640MB using an 8800GTX BIOS even though both use the same G80 GPU core. |
I wasnt asking if you could flash a 3870 bios on a 3850, but rather why isnt there a BIOS flash for the 3850 like there is for the 3870, seeing as they are the same core.
if the cores are the same they are the same are they not? if they are "electronically different" then they are not the same cores and should have different names.
