Old October 30, 2010, 01:57 PM
Default Popped Cap replacement on an fx7300gt
I just aquired a pair of fx7300gt 256meg cards for what i thought was a good deal. seems its a case of buyer beware as i discovered after i got them home that the some of the caps are popped. wondering if there is anyone out there with experience replacing caps on video cards, if its likely its just the caps (there are only two of the larger ones burst) or something else as well. also, the caps are poorly labeled and im having a hard time finding replacements. i believe they are 1500micro farad 6.3v. they top of the cap says JL 1500 6.3v and thats it. ill upload a pic if thatll help. Any advice would be really appreciated.
Old October 31, 2010, 09:03 AM
Soultribunal's Avatar
Upload a pic if possible. Usually electrical supply stores will carry Capacitors and such.
Or you could buy them where I Do online at Digi-Key. I get most of my electronic stuff from them, Usually its because I am replacing bad caps in Flat Screens that wouldn't come out of sleep mode.
ST
www.realhardwarereviews.com
Old October 31, 2010, 09:33 AM
BrainEater's Avatar
roger that on the flatscreens not coming outta sleep mode...and bad caps on motherboards and powersupplies etc etc etc...
/rant
yea a photo would help.
Typically in 'non-psu' devices , electrolytic capacitors are used in a filtering capacity , so the values are not so important , as long as they are 'big enough'.
I usually replace with the same or larger capacitance , and 'the-next-highest-voltage-rating'.
Supermicro X11DPi-NT:2x Xeon Gold 6144's:Lots more other stuff.Dual 4k monitor video .
Old October 31, 2010, 10:37 AM
Dr_BenD_over's Avatar
Fallen Folder
Gotta love 7300GT's and blown caps
DigiKey Corp. | Electronic Components Distributor | Canada Home Page or .com or whatever. I think they have like a minimum $20 order though. They're a pretty common value, I had a bunch kicking around for fixing motherboards. Probably somebody selling them on Ebay for next to nothing.
All's well that's Haswell
Old October 31, 2010, 11:50 AM
Default Uploads of two fx7300gts with popped caps
Great, thanks for all the help! Ive used Digikey in the past for projects, I'm just unsure what to order. If someone could give me a part number I would really appreciate that! Also, would I just replace the popped ones or should I replace all the caps in the same area? Is there a general rule of thumb for this stuff? Thanks again for all your help
Old October 31, 2010, 11:54 AM
Umm I can try looking at the site and see what I find.
I wonder if those are the Aluminum style Caps that you have popped.
At this point, I"d say don't take the chance and replace them all. And Digi Key is pretty damn good, if you send them in a Picture they can usually find it.
I've done that in the past.
ST
Old October 31, 2010, 12:11 PM
Default caps
Yes, they are aluminum. The top of them say JL 1500 6.3v. I am guessing this is the manufacture the farad and obviously the voltage, but on digikey i couldnt find that info and I dont know what is a safe alternative.
Old October 31, 2010, 12:31 PM
if you can spare a few more cents, get some 'heavier' caps to replace them with.
Old October 31, 2010, 04:21 PM
Fallen Folder
1500F, 6.3V, General Purpose, 20% (higher capacitance and voltage won't really matter these are for bulk storage anyway)
You'll have to measure the lead spacing and the height (if you have height restrictions) Panasonic, Nichicon and United Chemi Con are all good brands. My best guess based on the pic's is
Digi-Key - P10203-ND (Manufacturer - EEU-FC0J152S)
I would replace ALL of the capacitors of that size even if they haven't popped.
Old October 31, 2010, 06:59 PM
Default help
Right on. thanks for your help and the info.
Tags
capacitor , card , replacement , video
Large improvements in xfire with CAP 10.8a thorn Video Cards 6 August 30, 2010 11:39 AM
The real Cap.Price? cmac79 Off Topic 1 July 10, 2010 03:11 PM
CAP LAN this weekend! Polygon Canadian LAN Parties & Events 0 March 22, 2010 06:45 PM
Going over the Cogeco cap? Jonwall Networking 0 January 23, 2010 08:47 AM
Need options regarding soldering a cap 3.0charlie Troubleshooting 39 October 25, 2008 07:50 AM
