Old October 25, 2010, 07:35 PM
Default how much power do i need to support the Gagabit 6870 1GB on the regular systerm?
MY CPU is AMD Phenom X4 9500 is that good enough to match up with this video card?
THanks
Old October 25, 2010, 07:43 PM
A 600W would be a good place to start. Unless you want to do a crossfire x setup then get a 850W or higher.
Old October 25, 2010, 07:55 PM
Bond007's Avatar
a quality 500w will be enough, but 600w would give you some headroom
Old October 25, 2010, 07:57 PM
A good quality "brand name" 500 watt psu like Corsair, Antec etc...would be plenty to run that card. You could probably run 2 of them with a 500 watt...
http://www.google.ca/url?sa=t&source...tyUJ8Q&cad=rja
Old October 25, 2010, 08:13 PM
Look at the specs on my system. Playing games, running benchmarks I can't get my system to use more than 500watts.
Old October 25, 2010, 08:43 PM
One of my dedicated folding rigs which runs 24/7 is currently running 2 GTX 260's and a GTS250 off a 550 watt Antec with no issues whatsoever... I have never checked the power draw with a meter as I don't have one but the machine has never rebooted spontaneously or ever crashed...
Old October 26, 2010, 04:23 AM
well, seeing how it consumes roughly 125-165 watts depending on usage (normal, extreme) , and your phenom cpu takes a good 120 watts, i would say a minimum on the 12v should be around 320-350 watts, which a green watts can provide, the 380 although that would push it to its max rated specs all the time. better go with the 430 watts one.
Old October 26, 2010, 07:39 PM
Thank you for all the helpful respond.
I know what i need to buy now!
Thanks again.
One thing i wanna mention that OCZ is really cheap but i doubt their quality.
Old October 26, 2010, 07:56 PM
BrianHanna's Avatar
im using 2 4870s overclocked with 750, pretty sure one 6870 uses less power than a 4870, i think.
500 is definitely enough for a single 6870, but i'd go higher just in case you ever want to upgrade to crossfire or something (if that's what you mean to say, then sorry for the "correction")
Asus p6x58d-e / i7 930 @ 4ghz / G.skill 1600mhz 2x3gb 9-9-9-24 / Corsair TX750 / XFX HD 6850 1GB x2 @ 870/1070/ Coolermaster HAF 932 / Noctua nh12-up / Western Digital 500g Caviar black /Western Digital 1TB Caviar black 60Gb/ Seagate 7200.11 500g / OCZ Vertex 3 SSD / Samsung 2253BW / G5 / MX518 /
Old October 26, 2010, 07:57 PM
BrianHanna's Avatar
Thanks again.
Quality for PSUs, go Corsair, you don't want to cheap out on your PSU, you can destroy your whole right, and they are PITA to replace, especially if you don't manage those cables properly.
Comment Thread for AMD Radeon HD 6870 & HD 6850 Review SKYMTL Video Cards 211 November 5, 2010 01:14 PM
how much power do i need to support the Gagabit GT460 1GB and the systerm? laplapmax Video Cards 1 October 14, 2010 08:06 PM
SPARKLE Announces GeForce GT 220 1GB DDR2 Graphics Card With Low Power Passive Cooling Design mikellini Press Releases & Tech News 6 May 28, 2010 11:24 PM
5000+ BE or regular 6000+ Scart CPU's and Motherboards 4 September 17, 2008 10:20 PM
