Old October 11, 2010, 12:29 PM
Sagath's Avatar
I have to agree with Zero.
I disagree, the low end cards are all about your INTENDED use. Thi is a great HTPC card, sure, and I can see why Sky chose to focus on that. This isnt a gaming card, nor is the 56xx series, really. These are IGP replacements, HTPC cards, and very light gaming. Thats it.
And as to the "450 is better" comment from Lark, I felt the same about the 450 vs 460. I guess the point isnt so much "is X better" but rather just your maximum budget without going over. I would agree with you however that finding a used 98gt/260/etc would be a better buy...
Old October 11, 2010, 01:48 PM
SKYMTL's Avatar
HardwareCanuck Review Editor
Originally Posted by geokilla View Post
Is there going to be something to slot in between the GTS 450 and GT 430?
Yes.
Originally Posted by LarkStarr View Post
I don't know...
for the money offered, spend an extra $40 and get a well more equipped 450 if you need a new and recent card, else just find an older 200 series model for $30-50 without tax and be happy.
$40 is A LOT. Think about it this way. $40 added to a $200 isn't all that much. $40 added to an $80 card is a MASSIVE price increase for its intended market.
Old October 11, 2010, 02:04 PM
sswilson's Avatar
Are you using the same WU for all of your FAH GPU3 tests? If so, is that a 10632?
Old October 11, 2010, 02:12 PM
What's the issue with DDR5 HD 5550 cards? Can one even find HD 5550 DDR5 cards in Canada? If so, where?
For $80, what is the best/better choice out of?
HD 5550 (DDR5 version)
HD 5570 (is there a DDR5 ver.?)
GT 430
HD 5670 (some sales currently have it at $80*ish... although that's only momentarily? )
Old October 11, 2010, 02:17 PM
GT 430
The answer to your question is extremely obvious. See if you can figure it out by yourself.
Old October 11, 2010, 02:27 PM
interesting. i see asus has omitted an sli connector. guess theres no need for that.
performance per watt is kinda sucky, same with performance per dollar .
but overall wattage numbers are nice for what it does,meaning displaying movies to your tv/lcd :). could be better, but hey.
nice review sky, fail product :p
Old October 11, 2010, 02:36 PM
Low-end cards don't have SLI connectors.
Old October 11, 2010, 02:37 PM
Bringing lossless audio to entry level is nice. It just lacks in the price point a bit. and noise level.
  #19 (permalink)
Which one? There's more than one question.
I included the HD 5670 only because it's a close price bracket at the moment but probably not for long. I probably shouldn't have included it in that bunch. I guess I'm mostly wondering between the comparable Nvidia and ATI cards. I would prefer a DDR5 card but I'll probably only get a budget, entry-level card when I'm ready to buy. I think I'll go with either Fermi or Evergreen but looking at $80-ish or whatever is around there at time of purchase. I'll upgrade later.
  #20 (permalink)
Old October 11, 2010, 02:43 PM
The third one. The other two are pretty inconsequential once you've answered that one.
PNY GeForce GTS 450 1GB XLR8 Review Comment Thread SKYMTL Video Cards 2 September 29, 2010 03:59 AM
ASUS Radeon HD 5850 1GB DirectCu TOP Review Comment Thread SKYMTL Video Cards 20 September 12, 2010 07:15 PM
Cooler Master Elite 430 ATX Case Review Comment Thread SKYMTL Cases 14 August 8, 2010 12:20 PM
ASUS Radeon HD 5870 1GB V2 Review Comment Thread SKYMTL Video Cards 27 May 26, 2010 09:46 AM
