Old October 7, 2010, 09:12 PM
Cobrajr122's Avatar
Default GTX 280 GPU2 not underclocking
Title says most of it.
I have 2 EVGA GTX 280 ssc's. When they are idle, one under clocks itself, and one does not. I would like it to also under clock to lower temps and power usage.
I have done some googleing and not much comes up, mostly people trying to stop it from downclocking. So no luck there :(
Anyone have any ideas?
Thanks!
Old October 7, 2010, 09:15 PM
does this happen with sli enabled, or both?
Old October 7, 2010, 09:17 PM
Cobrajr122's Avatar
This is currently happening with SLI enabled, Ill disable it and edit this post with and answer for you.
EDIT
With SLI OFF - GPU2 drops down to the normal idle under clock, and GPU 1 now sits just above the idle under clock.
So is there a way to fix this while keeping SLI on?
Old October 7, 2010, 09:42 PM
rjbarker's Avatar
Been down this road a few times....its always Driver related....try a previous Driver that they downclocked properly with......which Driver are you presently using?
Classified Ultra SLi "Procyon"
http://i30.photobucket.com/albums/c3...2/DSC02888.jpg
http://i30.photobucket.com/albums/c3...2/DSC02889.jpg
Evga 4.2 Ghz Club....
Old October 7, 2010, 09:53 PM
Cobrajr122's Avatar
I am currently using the newest beta drivers.
Old October 7, 2010, 10:09 PM
beta :)
go back to the nearest whql.
Old October 7, 2010, 10:43 PM
rjbarker's Avatar
258.96 or as I said, the last version which the Cards downclocked properly on...during the 19x.xx Driver release, I stuck to my 18x.xx Drivers as none of those newer Drivers would downclock my 280's properly......btw, my 480's are downclocking fine on the 260.xx Beta's....
Old October 9, 2010, 09:42 PM
Cobrajr122's Avatar
I have dropped back down to 258.96 and the problem still persists in SLI mode. :(
I guess Ill just have to live with it.
Old October 9, 2010, 09:51 PM
rjbarker's Avatar
^^^^ 1 Driver change may not solve it.....don't give up...try a few of the previous Drivers until you find one that it functions correctly......was 258.96 working (downclocking) your Cards properly? Are you doing a "clean install"..?....as in Driver Sweeper, CCleaner etc etc....also uninstall and re-install Precison (if your using it)..as in clean install Precision after clean install of Drivers. Trust me....I have been down this road...
GTX 470 Underclocking Problem Iphikratous Troubleshooting 5 September 1, 2010 04:50 PM
GTX 280 vs GTX 280 SLI...Benches rjbarker Video Cards 39 November 16, 2008 03:36 PM
XFX GTX 280 or e-VGA GTX 280 CrimsoN Video Cards 13 October 17, 2008 11:40 PM
GTX 280 vs. GTX 260 vs. 8800 GTX review -n7- Member Reviews 11 September 27, 2008 10:00 AM
