<~----> new topic... gtx 280 sli or tri? - Page 3 - Hardware Canucks
  #21 (permalink)
Old October 3, 2010, 09:26 PM
Well, you're the one who has to figure out what you want. That's something I can't help you with.
  #22 (permalink)
Old October 3, 2010, 09:49 PM
if you know you will sell the 260's? sell them tomorrow. dont wait even a week. ;)
  #23 (permalink)
Old October 3, 2010, 09:53 PM
CTA's Avatar
CTA CTA is offline
zero... well you managed to change my mind about mobo... so you can do ;p
hahaha... well i will go to check if my d-tek unk sink and gpu can fit other card... hopefully so... ;[
edit: no it wont... hmmm will someone want this >;[
NEW: customize case, hx100, i7 920, supreme hf, x58 sabertooth, 3gbx2 ram of ripjaws, xfx hd6950 CF. vertex 2 60gb, seagate and hitachi 1tb, dual mcp355 with ek rex v2, 2x koolance ar697, 2x mcr320, 6x zm-f3 fans.
OLD: cm 690, hx620, intel q9450, True Black, ga-ep45-ud3p, 2gbx2 ram of mushkin xp2 8500, xfx 285. wd caviar se16 640gb, 4x zm-f3 fans.
  #24 (permalink)
Old October 3, 2010, 11:09 PM
You got nothing to worry about for GTX 260 sli as long as the game is supporting sli........I mean the scaling is not perfect, but good enough to match with GTX 470 performance in most of game...
Dx11 is just a joke so far, few games are supporting it and no much real difference even in most of time, unless we are talking about apparent drop of FPS
By the time DX11 shines, I believe GTX 470 cant even run game well already.........
  #25 (permalink)
Old October 3, 2010, 11:28 PM
CTA's Avatar
CTA CTA is offline
i believe it outperform gtx 470 except gtx 480...
oh btw... i found about amd 6 series
AMD 6-series GPU information leaking like water through a sieve - Graphics Cards - Build - News - Atomic MPC
i think i have to use my gtx 285 for temporary...
  #26 (permalink)
Old October 4, 2010, 01:25 AM
GT7R's Avatar
You can try to find an another GTX285 and two of those will get you settled for a good chunk of time.
  #27 (permalink)
Old October 4, 2010, 06:42 AM
CTA's Avatar
CTA CTA is offline
nah the gen2 computer need it because i am going to give it to my brother...
and nobody tells me that i can use dtek gtx v2 and unisink on gtx 280 directly :o... i feel stupid...
now new title... how about gtx 280? (i am not too sure if i can use it on gtx 285)
used gtx 280 costs me 180cdn to up... >_>;
  #28 (permalink)
Old October 4, 2010, 08:22 AM
I don't see any reason to buy such an old card. If you want to upgrade, get something current-generation.
  #29 (permalink)
Old October 4, 2010, 04:23 PM
CTA's Avatar
CTA CTA is offline
i thought i already told you...
- new amd 6 series is coming soon << primary reason that i should be waiting...
- new game (mostly directx 11) is coming at early 2011 (probably Q2)
- gtx 280 should perform better than gtx 470... (260cdn used vs 300+cdn + 12% hst) because gtx 470 didn't impressive me enough... gtx 480 is so-so and did about 30-40% better than gtx280 and for 450cdn :? ati 5870 improved a lot over old 4xxxx but not enough to beat gtx 480...
and another reason i asked because of dtek gtx v2 + unisink is only fitting on gtx 2xx 60nm... i should use it rather than sell for cheap... consider it as my gpu w/c lesson... i dont care if its leak or not ;p
  #30 (permalink)
Old October 4, 2010, 04:30 PM
The GTX 280 most certainly does not perform better than the GTX 470. As for the waterblock thing, buying a GPU based on the waterblock you have is not a good way to make a choice in my opinion.
From what I understand, you have a GTX 285 now. Is that correct? If so, then just keep it for now and make a decision in the future if your needs change. Based on what you've told me about the resolutions you use, you should already be able to run any game anyway.
Tri Sli GTX 280's - Porn For Geeks rjbarker Case Mods, Worklog & Gallery 30 August 7, 2009 12:27 PM
Help with F@H on quad-SLI GTX 295 please! zlojack HardwareCanucks F@H Team 52 June 10, 2009 05:09 AM
GTX 295 sli vs GTX 275 tri-sli phil3_66666 Video Cards 12 April 29, 2009 11:03 PM
GTX 260 (216) n 260 (192) in SLI? rjbarker Video Cards 4 September 23, 2008 11:47 PM
Tri SLI, Quad SLI, SLI comparisons with 9800GTS, GX2 Babrbarossa Reviews & Articles from the Web 3 March 31, 2008 02:32 PM
