Old October 2, 2010, 10:44 PM
Default Diamond 4870x2 no screen
I installed my 4870x2 and it powers on, the fan spins, however i do not get any screen. It does not show any red LED, which means there is no power problem or card problem. Can someone direct me what to do. Thanks
Regards
Xin
Old October 3, 2010, 12:22 AM
could you plz update your system config drop down thingie so we know what we're dealing with? :)
and then, does the computer work well with another gpu? power cords connected, nothing is shorting, the psu is capable,the works?
Old October 3, 2010, 06:14 AM
Hi,
Thanks for the reply. MY system specs is:
i7 860
Asus p7p55D premium
8gig g.skill trident turbulence
Antec TPQ-850 TruePower Quattro 850W
I have used the powersupply in a crossfire 5870 mode, so it should supply sufficient power. The 4870x2 (i have two of them) one of the works fine. The other one turned on once, and i used to watch video. Then it froze and shut off, and i never was able to turn it back on again.
Old October 3, 2010, 08:40 AM
ok so with another gpu it works fine?
then you know your problem. see if its overheating, aka the fan doesn;t turn, or the hs is loose(shouldnt be but you never know) maybe something is shorting out(piece of tinfoil from chocolate fell in there? )
Old October 3, 2010, 10:24 AM
Yea the fan turns, and it powers on without any error indication from the card. Just have no screen for some reason.
Old October 3, 2010, 10:29 AM
well the cards at fault, if you troubleshooted everything. no warranty right?
Old October 3, 2010, 10:34 AM
Can you test the card in another computer?
Old October 3, 2010, 11:44 AM
Tested the card on another computer and still no go, i guess the card is dead. Now the question is, what can i do with this card? Dumpster or is there warranty left?
Old October 3, 2010, 11:46 AM
read above :)
what make is it? are you the first owner? when did you buy it? do you remember who you bought it off of?
Old October 3, 2010, 11:49 AM
Lpfan4ever's Avatar
Have you tried both DVI ports? I know sometimes my card refuses to display out of a certain port.
Originally Posted by encorp
Code:
<firebane> slightly used
screen res controlled by actual screen or laptop supaflyx3 Mobile Computing 3 July 29, 2010 08:36 PM
[FS] Diamond HD 4870X2, EK Full coverage block Dr_BenD_over Buy/Sell & Trade 14 June 3, 2009 04:51 PM
It's here - Diamond HD4870X2 Dr_BenD_over Video Cards 12 August 29, 2008 08:01 AM
