Old September 30, 2010, 07:00 PM
Default How tight is tight
I installed an Artic Cooling Twin Turbo Pro onto my 4890. The setup comes with some spacers to sit between the the heatsink plate and the gpu. My question is how tight to I tighten the screws? I crisscrossed as I tightened down the screws. Do I want the spacers to compress a little?
Old September 30, 2010, 07:06 PM
its hard to explain, but turn until you need lots more force than the last 1/2 - 3/4 turn. over tightening=no good, as you have implied, sir :)
Old September 30, 2010, 07:09 PM
martin_metal_88's Avatar
Stick your finger in your pooper, this tight:) No seriously, you want them to be almost completly screweb like dan said.
Ask for more
Martin_metal_88
Colenzo : See system spec!
Odysseus : I7 860 @ 3.6Ghz || GA P55-UD5 || G.skill Ripjaws F3-16000 2000Mhz 2X2GB || Coolermaster ATCS 840 || Silverstone Strider plus 850W || WD 640 black - WD 1TB green - Samsung F3 2TB || MSI 5670 1GB Cyclone ||Coolermaster Hyper 212 + ||
Old October 1, 2010, 11:45 AM
Caldezar's Avatar
Well this thread is dissapointing! Not about anything I was hoping for...
But back on topic... With the Twin Turbo Pro, you should be able to look at the card from the side and see that there's solid contact with the GPU. If you've tightened it up and you still see there's a space or bad contact between the GPU and the cooler, then there's a problem in either how you're installing it, or the product. If you're not sure how the contact is, pull the cooler off and look at the spread of the TIM to get an idea.
*EDIT* - Here's a video with an install walkthrough in case you're not sure...
YouTube - ARCTIC COOLING Accelero Twin Turbo Pro Review on ATI HD5870
Motherboard screwed too tight? RLP06 New Builds 8 May 2, 2010 01:43 PM
newb tight budget build Weak15Ten New Builds 4 August 5, 2009 11:04 AM
How tight is tight? Beermaster Water Cooling 5 July 18, 2009 08:10 PM
Mem. OC. High FSB vs Tight timings Gooses Overclocking, Tweaking and Benchmarking 1 September 3, 2008 09:31 PM
Tight Budget Overclocking! Digital_fx3 Overclocking, Tweaking and Benchmarking 18 April 27, 2008 03:52 PM
