-   -   Running 2 GTX 460 cards at once (http://www.hardwarecanucks.com/forum/video-cards/36643-running-2-gtx-460-cards-once.html)
lechumbl September 28, 2010 06:01 PM
Hi all,
I ran a search and did not find any other threads with this, so if there is one out there, please forgive me in advance.
I was running a single GTX 460 and a 9800 GX2 together and all was well and the switches were correct.
I decided to pull and sell the 9800 GX2 and replace it with a second GTX 460.
The single GTX 460 was producing 13,100 ppd.
With the second GTX 460, both dropped down to approximately 6600 each.
What do I need to do to get both back up in ppd?
I have both directories in d drive and and they seem to be OK.
Take care, and thanx in advance for any help on this.............
lowfat September 28, 2010 06:28 PM
What CPU are you using? Are you running an SMP client at the same time?
lechumbl September 28, 2010 06:34 PM
Hi all,
Duh on my part, I always give folks a hard time for not giving enough info, then I do it. :rofl:
Go figure.
I am running an Asus PQ5 Pro Turbo mobo, an Intel Xeon X3370 3.0 Ghz quad, and 8 gigs of OCX XTC Platinum 1066 memory.
I am running SMP, as before the switch to the GTX 460.
Take care, and thanx for the reply..............
lowfat September 28, 2010 06:44 PM
If you use MSI afterburner what does the GPU usage graph look like?
Also try stopping the GPU client for a short while and see if the PPD increases.
lechumbl September 28, 2010 07:14 PM
Hi again,
As I said before, when the single GPU is running, the ppd is 13k+, it just splits in half for each GPU.
It should run both at about 10k, when settings or such are correct.
Each core is running at 100%, as it has been for as long as I can remember.
Take care..........
_dangtx_ September 28, 2010 07:19 PM
so precision says that each gpu is going at 100%? somethings really amiss there. im thinking they are being starved of the few necessary cpu cycles they may need? :)
lowfat September 28, 2010 07:20 PM
Opps I meant pausing the SMP client to see if the GPU scores increase.
I am assuming you have one w/ a GPU 0 flag and the other w/ a GPU 1 flag?
Sagath September 28, 2010 07:58 PM
Assuming lowfats suggestion has been done, set both your tray clients to 'slightly higher' use so the CPU doesnt steal GPU data time.
Also, be aware that if you plan on running -advmethods on both GPUS it will eat up alot of SMP time and your PPD will likely go down.
lechumbl September 28, 2010 08:30 PM
Hi _dangtx_,
My cores have been running at 100% for years.
And my production, with the exception of changing yesterday, has been in the upper 30K range.
I really don't know what to say about that.
Hi lowfat,
Yes that GPUs have been running the correct flags for a long time too.
Hi Sagath,
I have not been running the -advmethods fllag for some time.
Take care.............
lowfat September 28, 2010 09:16 PM
Originally Posted by lechumbl (Post 433706)
Hi lowfat,
Hi Sagath,
But didn't you say you just installed the second GTX460 yesterday? So you would have needed to download the new GPU3 client and re add all the flags.
You have the GPU3 client installed for both of them correct?
