Old September 26, 2010, 01:09 PM
Default 4890 in crossfire question.
I currently have 2 MSI 4890 running in crossfire. One is on a x16 and the other x4. What will this do for performance? Thanks
Old September 26, 2010, 01:46 PM
Keltron 3030's Avatar
Hey man! Welcome to the forums!
as for your question, it might impact performance, but how much I am not sure of. Its most likely not enough to even worry about it.
btw, what are the specs of your computer?
FFFFFFFUUUUUUUUUUUU-
Old September 26, 2010, 03:54 PM
not sure about your cards, i nwhat resolution,at what settings but check this out
Old September 27, 2010, 04:03 PM
System is:
AMD Phenom X5
4G DDR3
Dual 4890's
Running at 1980x1020
Old September 27, 2010, 04:42 PM
DkRk's Avatar
[H] did a test using a pair of GTX 480's in a 4x/4x PCIe configuration, and the results were actually quite positive:
GTX 480 SLI x16/x16 vs. x4/x4 - GTX 480 SLI PCIe Bandwidth Perf. - x16/x16 vs. x4/x4 | [H]ard|OCP
You should be A-OK.
Protect your chicken from Dokken.
Crossfire Question cul8erppl Video Cards 6 July 14, 2010 06:35 PM
4890 vs 4870X2 Crossfire? Luckk Video Cards 6 November 24, 2009 10:19 PM
crossfire question ultraman7k Video Cards 13 November 4, 2009 02:06 PM
crossfire question ToXic Video Cards 2 August 7, 2009 12:39 PM
IS the 4890 crossfire compatible with the 4870*2? sheepdogexpress Video Cards 6 June 8, 2009 06:33 AM
