Originally Posted by areszues92 Umm, that means if i set everything to max my gpu will be bottlenecked? |
Well, sort of. It all depends on the game and the resolution you're running.
If you're concerned about bottlenecking, then the easiest thing for you do (so you won't be confused) is just forget everything go with this.........
Search online for a GOOD review of the card you are going to buy. Once you get your card installed, run some games and benchmarks with similar settings used in the review. Note your results. Then compare it to what you see in the review and try to determine if your CPU is good enough or not. You don't need to be anally thorough. Just get yourself a ballpark idea regarding your rigs performance.
If the results are similar (within 3-4 fps) then your laughing.
If the rig in the review that you're comparing to is getting way better results ( around 5+ fps) then what your system can produce in the same test, then your cpu will obviously be bottlenecking your graphics card.
