Old September 19, 2010, 09:38 PM
I'm a greenhorn at doing this stuff. I still don't get the tutorials. I know how to get to BIOS, after that i know nothing. But someone from another forum said i should get 1 GB version to get more AA out of games to reduce bottlenecking.
Edit: Read from another forum. It says chucks rule, do not overclock if you cant afford to replace it if anything goes bad. I cant afford a new CPU, and my CPU is already obsolete.
Old September 19, 2010, 10:57 PM
Dumb rule. You'd have to do something amazingly stupid to kill your hardware. There are lots of members here who would be more than willing to help you get a safe, stable overclock.
Getting past the initial "fear" of overclocking is the biggest step. After that, it's all downhill.
Old September 19, 2010, 11:19 PM
how about the 1 GB vs 768 MB GTX 460, which is best for my system.
Old September 20, 2010, 10:08 AM
768MB, considering you're @ 1440x900.
Old September 20, 2010, 06:29 PM
All right, I'll buy the GTX 460 768 MB first.
Old September 21, 2010, 05:58 AM
Are there any benchmark for Intel core 2 duo and a gtx 460?
Old September 21, 2010, 07:08 AM
The best way i know of to reduce bottlenecking is at the build stage when you pick your components, and sometimes that means knowing if your going to overclock up front and picking components with that in mind. There will always be one item i.e. Motherboard, CPU, GPU etc.. that will be the overall bottleneck to the system however you can reduce the impact as much as possible with proper planning. Based on your current Spec, resolution etc.. the 768MB 460 was a good choice/suggestion unless you want some wiggle room for the future.
Cheers; Snarl
Another Guy From Canada
Old September 21, 2010, 07:18 AM
martin_metal_88's Avatar
There is probably no bench since most site use recent ( and overkill ) hardware to make their benchmark. But, if you are over a E7300 I am sure there will be no bottleneck. In the worst case, OC time :) Can you tell us what is your complete system?
  #19 (permalink)
Old September 21, 2010, 07:42 PM
Intel Core 2 Duo E6750
2 GB DDR2 667 mhz
P5K-SE mobo
ASUS 8600 GT 512 MB DDR2
320 GB HDD
19 inch HP monitor
  #20 (permalink)
Old September 21, 2010, 08:16 PM
Ok so, your CPU will probably bottleneck a LITTLE bit but nothing dramatic. Your screen also helo you in that. Since you play at low res you will notice no difference. IMO, as long as you stay with this screen, there is no need to change anything and the 460 will work fine ;)
BottleNecking? Chromey Video Cards 10 April 6, 2009 05:36 PM
i7 Build help reduce $ without loss k4kman New Builds 10 March 11, 2009 12:57 PM
Does overclocking reduce product life? triumph Overclocking, Tweaking and Benchmarking 12 July 27, 2008 08:26 AM
Memory Makers to Reduce Supply? MpG Press Releases & Tech News 7 December 12, 2007 09:36 PM
What do you suppose is bottlenecking this PC? LookAQuesadilla Troubleshooting 14 April 30, 2007 09:16 AM
