Old September 17, 2010, 09:52 AM
Slik's Avatar
Default Older SLI Bridge O.K?
I received my new Area 51 with Nvidia cards this time. Dell installed them using the standard short bridge. I need to separate them but the only longer bridge I have is one I used with two GTX 280s a while ago. Will that bridge work with two 480 GTXs? I don't want to experiment and maybe screw it all up. Thanks for any input.
Thermaltake Level 10-i7 3930k @ 4.2ghz. Liquid cooled-4x4gb G Skill Trident X DDR3@ 1600mhz- Two EVGA Titans SLI - Xonar Phoebus Sound Card-Dell 3008 30" Monitor-Razer Tiamat Headphones-Butt Kicker Gamer-TrackIR 5
Old September 17, 2010, 09:58 AM
SugarJ's Avatar
There's only one version of the SLI bridge. Any one should work fine.
Old September 17, 2010, 09:59 AM
Slik's Avatar
Thanks. Here I go.
Old September 17, 2010, 12:07 PM
rjbarker's Avatar
- Flexible
- Stiff for Sli
- Stiff for Tri Sli
- Stiff for Quad Sli
Any one of the above will work fine, just remember when installing the 2 x Sli Bridge to get it on the right connectors (closest to the GPU exhaust)....I use the stiff Tri Sli Bridge ;) ....for aesthetics (sp).....and in reality, thier has beenno need for the Bridge fof sometime.....slight increase Benching only....cannot remember which Driver version did away with te Sli Bridge, quite a long time ago..could have been 18x.xx
Classified Ultra SLi "Procyon"
http://i30.photobucket.com/albums/c3...2/DSC02888.jpg
http://i30.photobucket.com/albums/c3...2/DSC02889.jpg
Evga 4.2 Ghz Club....
Old September 17, 2010, 12:45 PM
i take it for higher resolutions its a good idea to leave it on? :)
Old September 18, 2010, 07:38 AM
Technokat's Avatar
i was debating doing the same thing, to seperate my 480's out a bit for cool runninz :)
Old September 18, 2010, 09:23 AM
rjbarker's Avatar
You mean you run your 480's right next to each other?...as in no empty PCI-E slot between them? .......why? let em "breathe"....
Old September 18, 2010, 11:05 AM
Slik's Avatar
I have two bridges that are the long ones. I read that using two bridges is pointless as there is no difference than using only one.Is this correct? Should I use both bridges?
Old September 18, 2010, 11:12 AM
Slik's Avatar
You may not be able to leave the video card shroud on once you separate the cards. There is a lip at the bottom that will not slide past ypur cards.Leaving the door off is better anyway but the lip at the bottom can easily be cut to allow putting the door back on if you wish. I did that with my last Area 51 and all was O.K. You need a good spin cutter and a steady hand. [Gotta say, I'm glad I went back to Nvidia.]
Old September 18, 2010, 08:18 PM
Slik's Avatar
As posted above, I'm surprised no one has advice. Is it better to use two bridges? Any performance benefit? When I had ATI cards,I remember reading that there was no benefit. Is that true for Nvidia as well? Surely someone here knows. Technokat? You have the Alienware with Nvidia,What do you use? Thanks all.
Jittering game play = broken sli bridge? 0o0 Troubleshooting 18 July 1, 2010 07:25 PM
[WTB] Triple SLI Bridge CroSsFiRe2009 Buy/Sell & Trade 2 June 29, 2010 02:23 PM
[WTB] SLI Bridge CMetaphor Buy/Sell & Trade 12 September 8, 2009 05:15 AM
[WTB] Sli Bridge for a EVGA 780i 7oPd4wG Buy/Sell & Trade 5 March 19, 2009 07:16 PM
Tri SLI, Quad SLI, SLI comparisons with 9800GTS, GX2 Babrbarossa Reviews & Articles from the Web 3 March 31, 2008 02:32 PM
