Old September 14, 2010, 11:18 PM
Default help with gtx 460
sup guys i just finished buidlign my rig .... and when i turn on... black screen :S:S:S:S... im goign crazy right now. i know card is well connected fan is on and everything.. ive checked everything and all seem fine... :(. i even tried an old pci card i have and no video also...
what are common mistakes for first time builder that can cause this type of problems?
pls help me :(
Old September 14, 2010, 11:21 PM
lowfat's Avatar
If you tried a different video card instead then chances are the video card isn't the issue. Try one stick of memory at a time.
Old September 14, 2010, 11:31 PM
coming from the other thread, ALL power cables properly plugged in? nothing shorting out?
do plz drop us some specs, memory fails us on the many questions and different builds around here :)
Old September 14, 2010, 11:39 PM
my memory is corsair dominators 2x2gb 99924 ddr3 1600mhx
amd 1055t 6 core
asus m4n98td evo mobo
gtx 460
i think everything is well connected all fans are on and everything... although i dont even get a beep from my mobo ... nothing... black screen
Old September 15, 2010, 12:21 AM
put it together on your table, this way stuff that might be overlooked may be not this time
Old September 15, 2010, 06:35 AM
Is the 4-pin power socket for your CPU plugged in? When I got my C2D, that one held me up for days because I was used to older Athlon/PIIIs that didn't use that power connector.
Or how about posting a picture of your computer's innards?
gtx 460 or 2 4850 or 2 gtx 260 sempifer Video Cards 14 August 29, 2010 01:18 PM
NVIDIA GeForce GTX 460 1GB & GTX 460 768MB Review Comment Thread SKYMTL Video Cards 126 August 20, 2010 10:01 AM
2 GTX 460's 1gb or 1 GTX 480 -InfiniteLoop- Video Cards 10 July 28, 2010 01:48 PM
