Old September 6, 2010, 12:47 PM
Default Overclocking 5970 at 1.22 volts
Hey guys I have overclocked my 5970 to 1000 mhz core and 1315 memory at 1.22 V. I was just wondering if anybody thinks that this voltage is too high for the card.
I have the Accelero XTREME for third party cooling.
Old September 6, 2010, 12:51 PM
geokilla's Avatar
What's the stock voltage? What are your load temperatures?
Old September 6, 2010, 01:08 PM
Load temps are 74 degrees celsius the stock voltage of the card is 1.05v although they recommend using 1.1625 as safe for achieving decent overclocks but I believe that is with a stock cooler.
Old September 6, 2010, 01:19 PM
if you can keep the temps low, adding extra juice won't be TOO bad, but with every extra millivolt you increase, the lifespan decreases regardless. I wouldn't go too much higher then that though personally.
Old September 6, 2010, 01:21 PM
Hmm that is what I was worried about. The temps are low but I'm not sure the overclock is worth risking the card.
Old September 7, 2010, 03:18 AM
you can use gpu-z to monitor your vrm temps, those things can get quite hot.
Overclocking a 5970 Higgy10 Overclocking, Tweaking and Benchmarking 5 July 25, 2010 11:59 AM
Radeon 5970 Overclocking: The VRM Temperature Bottleneck @ AnandTech geokilla Reviews & Articles from the Web 16 January 23, 2010 11:16 PM
What can I expect Watercooling my Q9450 at 3.8Ghz, 1.36-40 volts? superj Water Cooling 14 November 5, 2009 02:29 AM
Is my O/C (temps and volts) safe for 24/7 folding? divertiti Overclocking, Tweaking and Benchmarking 10 January 5, 2009 06:45 PM
OCZ Memory owners: Try your memory at lower Volts sswilson RAM 0 October 24, 2008 07:36 AM
