-   -   Can a 620W PSU run gtx 470? (http://www.hardwarecanucks.com/forum/video-cards/35933-can-620w-psu-run-gtx-470-a.html)
brando533 September 4, 2010 11:10 PM
Hey HWC
I'm upgrading my graphics card and i'm wondering can a 620W PSU run Gtx 470
Thanks
ZZLEE September 4, 2010 11:13 PM
post a system spec you will get better advice :)
SugarJ September 4, 2010 11:20 PM
Yes.
See power consumption graph here: http://www.hardwarecanucks.com/forum...review-29.html
Max of 354 watts on an overclocked i7 system. IIRC Nvidia recommends a 550w PSU minimum.
Bond007 September 5, 2010 06:54 AM
yes....if its a quality PSU you will have no problem. Even a cheap 620w should run it, but I would not risk a 470 on a junk PSU.
Zero82z September 5, 2010 08:41 AM
I'm surprised that nobody has asked the obvious question yet, but which 620W PSU is this?
paphman910 September 5, 2010 08:50 AM
Hopefully they are referring to the Cosair HX620 Power supply! It is a quality built power supply by Seasonic.
Paphman910
LarkStarr September 5, 2010 09:42 AM
Paphman910
what are you, a walking advertisement?
brando533 September 5, 2010 12:59 PM
its a seasonic i forgot the exact one i'm using a 460 atm.
Zero82z September 5, 2010 01:00 PM
In that case, it will be quite enough.
brando533 September 5, 2010 01:01 PM
Thank you
