Old September 2, 2010, 05:17 PM
Kommie986's Avatar
Default EVGA GTX 470 Question
If I wanted to disassemble the card to place a waterblock on it, I would have to remove all the screws. I know one of the screws is under a sticker (from a video below). I was wondering what that sticker said. I know on my XFX GTS 250, it says something along the lines of "Warranty Void if Damaged". Does it say the same/similar thing on the EVGA GTX 470 sticker?
YouTube - CMP: EVGA GTX 470 Disassembly
Old September 2, 2010, 05:55 PM
as far as i know if the card shows any kind of modification(yes they support third party coolers but dont touch the stickers,bork the card yourself) youre toast.history. not good :)
edit : now if you slowly peel it back? and dont break it? should be ok.
Old September 2, 2010, 06:14 PM
SugarJ's Avatar
That's EVGA's part number and serial number sticker, which does say warranty void if removed. However, since they accept the use of 3rd party coolers, I'm sure that if you simply expose the screw or replace the sticker when done you are OK.
Also, there's no reason to take the cover off the heatsink like he does in the video. Undo all the screws on the back and the 2 on the PCI plate, and the cooler comes off in one piece.
Old September 2, 2010, 06:46 PM
Kommie986's Avatar
So how do you guys recommend I take it off without breaking it? 0_o
Edit: Also, wouldn't I have to take if off if I'm going to add a backplate?
Old September 2, 2010, 06:54 PM
Use a craft/exacto knife to get under the sticker and peel it up until the screw is exposed. Take out the screw, place the sticker back down, problem solved. Just be careful, and make sure you don't tear the sticker while removing it.
Old September 2, 2010, 07:00 PM
Kommie986's Avatar
Ugh this is gay. They say you can add aftermarket coolers, but then they put a sticker over a screw you need to remove in order to add one...
Edit: I just called EVGA, the customer service (pre-sales) is surprisingly fast. The guy said I should be able to remove it without damage it. So yay.
Old September 2, 2010, 07:36 PM
get a name+agent number or else you never called......
Old September 2, 2010, 08:13 PM
rjbarker's Avatar
You'll be fine....do as Zero suggested, be careful, but even if you tear it slightly, remember which company you're dealing with.....evga's Customer Support will bend over backwards to make you a satisfied customer..I have dealt with them personally with a number of complex issues that arose during "Step-ups" and they were excellent.....I wouldn't worry ;)
Classified Ultra SLi "Procyon"
http://i30.photobucket.com/albums/c3...2/DSC02888.jpg
http://i30.photobucket.com/albums/c3...2/DSC02889.jpg
Evga 4.2 Ghz Club....
gtx 480 with gtx 260 for physx (power consumption question?) bvsbutthd101 Video Cards 15 July 7, 2010 10:37 PM
Koolance Releases GTX 470 & GTX 480 Full Coverage Waterblocks FiXT Press Releases & Tech News 7 April 9, 2010 07:34 PM
EVGA Announces GeForce GTX 480 & 470 Graphics Cards FiXT Press Releases & Tech News 0 March 29, 2010 11:02 AM
NVIDIA Clarifies Official GTX 480 and GTX 470 Launch Date matsta31 Press Releases & Tech News 76 March 9, 2010 01:07 AM
NVIDIA's Next-Gen Parts Get Named: GTX 480 & GTX 470 SKYMTL Press Releases & Tech News 67 March 6, 2010 08:23 PM
