Old December 6, 2007, 04:52 PM
abs0Lut's Avatar
Default Best aftermarket cooling for 8800GT.
Hey everyone just wondering if anyone has had any good or bad experiences with their aftermarket heat sink fans for the 8800GT. The Accelero S1 is the one I really want to buy but I am not sure how the whole thing works if you don't want to go just passive, such as is there a way to get 2 120mm fans on it with no modification/jimmy rigging from out of the box. Thanks a lot.
GPU XFX 8800GT Alpha Dog Edition
CPU Intel Core 2 Duo E4300
MOBO DFI P965-S
RAM OCZ Plat. XTC Rev. 2 2GB
HDD Western Dig. 250GB
CASE Antec P180B
PSU Silverstone Element 500W
Old December 6, 2007, 05:08 PM
We have someone that reviewed the S1 on an 8800GT here 8800GT + Accelero S1 = Love?
You can use Zip-ties to attach a fan or two of your choice :)
I was originally going to go for the S1 on my card, but then it would interfere with the side door fan on my antec 900. So I went with the VF900 (got it for $20 open box) Zalman instead.
Q6600 G0 @3.5ghz (Thermalright Ultra X 120)
Asus Maximus Formula 903
A-Data DDR 800 4 x 1gb, EVGA 8800GT SSC (Zalman VF900)
Antec NeoPower Blue 650W, Antec 900
HTPC: X2 64 5000+ Black @3.3ghz (AC 64 Pro)
A-Data DDR 800 2 x 1gb, Radeon 2600 Pro HDMI
Asus M2N-E, Antec Sonata, 380W TruePower
Old December 6, 2007, 05:12 PM
..'Ant'..'s Avatar
Here's another one:
Thermalright HR-03 GT
Thermalright VGA Backside Cooler HR-11
Old December 6, 2007, 06:31 PM
3.0charlie's Avatar
I have the S1 on my 8800GT with dual 120mm fans, installed using tye-wraps (zip ties). Silent setup and allows the card to run very cool (47C load).
Hydro-Quebec is salivating...
Old December 7, 2007, 06:37 AM
abs0Lut's Avatar
Could someone tell me if the warranty from XFX allows me to change the HSF?
MOBO DFI P965-S
CASE Antec P180B
Old December 7, 2007, 07:09 AM
3.0charlie's Avatar
No problem replacing the stock heatsink with an aftermarket model.
Old December 7, 2007, 08:49 AM
Won't find anything cheaper than the S1 to work so well with a 120mm fan.
Old December 7, 2007, 09:22 AM
donimo's Avatar
I have the S1 with the turbo module, 2 (80mm?) fans that clip right on to the fins, so quiet that you will cut your ear on the blade before you hear it and it cools my overclocked 1950pro (I know its not as hot as 8800gt, but still) to 30C idle, 41C full load...
turbo module is only 8 bux
Mobo GA-Z77X-UD3 CPU i5-3570K stock RAM:2x4GB Patriot Viper 1866 1.5v GPU:XFX HD6850 BE + Gigabyte HD6850 @820/4400MHz Case:Bitfenix Raider w/2x 200mm + 135mm PSU: Corsair HX620
Old December 7, 2007, 02:31 PM
abs0Lut's Avatar
Yeah I was thinking about how loud the Turbo Module would be, I have a Antec Tri-Cool lying around here they are pretty quiet at low speed.
MOBO DFI P965-S
CASE Antec P180B
Old December 7, 2007, 03:08 PM
donimo's Avatar
turbo module is quieter than an antec tri-cool set at "low", can personally vouch for that.
WTB:8800GTX aftermarket cooler magictorch Buy/Sell & Trade 0 January 28, 2008 09:47 AM
What aftermarket coolers are compatible with 8x00series? AERo Water Cooling 5 December 18, 2007 01:26 PM
Cooling 8800GT in SLI AutomaticPixel Water Cooling 4 December 9, 2007 01:45 PM
XFX 8800GT very hot MajorBuzzon Video Cards 22 December 4, 2007 07:44 PM
