<~----> Must have Nvidia! - Page 2 - Hardware Canucks
Old August 30, 2010, 12:15 PM
Originally Posted by Linus View Post
If you guys are both so unhappy with your cards you should just trade...
I cant, i'm running surround 3d. ATI wont do 3d.
vista 64 on these rigs
Q9450 @ 3.5Ghz | E8400 @ 4.2Ghz
8gb Muskin Redline. | 2gb Kingston Hyperx
________________________________|_________________ ______________
EVGA 780i FTW ----\--||___||--/---- EVGA 780i SLI
Antec TP Quatro 1000W \ :==^==: / Antec TP Quatro 850W.
Nvidia 9800 GX2 X 2 SLI \|--o--|/ Nvidia 8800 GTS X 2 SLI
1X 500GB Western Digital. \_____/ 3X 150GB WD RAPTOR RAID-0
Old August 30, 2010, 12:21 PM
So what exactly is your problem with the ATI cards? Anyway, if you're concerned about heat, switching to GTX 480s isn't going to make anything better. However, there's absolutely nothing wrong with having your CPU running at 80C.
Old August 30, 2010, 12:44 PM
nice from dell to do that. if the new system is well insulated for sound proofing, you shouldnt suffer too much. watch the fan speeds o nthe cards, might want to not let it drop below 50-60 percent during normal use, above 80 pct for heavy duty use..
Old August 30, 2010, 12:58 PM
if he is running sli he wont need to watch the fan speed; they'll be 100% all the time ;D
Old August 30, 2010, 12:59 PM
rjbarker's Avatar
have fun with the heat and the noise.
did i mention the noise?
I've got 2 x 480 in SLI. they run hot... 96 degrees with the fans full out playing any game i've run. fans are noisy noisy noisy.
I dont like my 480s at all. cost way too much to have them water cooled so i could use them and not go def.
I should mention that the 480 is noisy.
Hot too.
This stuff really is getting old....I've Posted soooo many times I should simply "cut n paste' ;)
My 480 Sli's with my 920 @ 3.83 Ghz....Precision Fan Profiles:
Idle / Desktop / Web / MS Office etc etc = Fan Speed set to 55% = Barely Audible over my Case Fans (quite silent) = Max Temp 39C - 41C
Intense Gaming (Metro, JC2...yada yada yada) = Fan Speed 80% = Certainly Audible, but NOT obnoxious = Max Temp 80 - 83C
Bottomline....(from my experience with these Cards)...if you have to run the Fan at 90% or higher and still get Max Temps higher than 85C (in game), then you simply have to improve the Air Cooling in your Case.
In my System, I added a Xiggy 140mm Intake into my side window to force cool air onto the Cards, the TJ09 also has a front 120mm intake forcing cool air directly into the GPU intakes..
I love my 480's....but you really have to prepare your Case for them....or get WB's ;).......or as Linus said, get rid of em if you hate them that much!
Old August 30, 2010, 01:12 PM
your just not working them hard enough Mr. rjbarker ;D
your right of course, with a proper case and air flow, a single monitor and a bit of good luck, they are only mildly annoying
Old August 30, 2010, 02:08 PM
fishingfanatic's Avatar
Smile Video Cards
Each has their own good and bad. When I had a Cosmos with a pair of 5970s in xfire, the 2nd card hit 101 C. I mounted a fan behind them and the temps never got above 86 C after running Prime 95 for over an hour.
Then I switched cases to a HAF X. It comes with a fan shroud that mounts behind the gpus. The 5970 was a bit too big without modding. I installed a single 480 and added a 90 cfm fan. I can put my hand on the card at any time without any heat at all. If you go sli, an extra fan behind the gpus couldn't hurt. Perhaps they can install one for you.
Old August 30, 2010, 02:45 PM
BT!'s Avatar
BT! BT! is offline
how do you test graphics cards with prime95?
  #19 (permalink)
Old August 30, 2010, 03:38 PM
Smile Video Cards
I didn't test with Prime 95, if I remember correctly I had gpu z running as well during the run as I had those 2 cards so close, they were almost touching. That's why I ran the stress tests, to make sure things wouldn't run too hot, as when 1st installed, the cards were really warm. It really made a difference wit h the extra fan. The 480 was so much cooler that I didn't even check the temps. Mind you, a 90 cfm fan is moving a big pile of air. The HAF X fits the bill for high air flow and the fan is only 16 dbs so you can't even hear it.
Edit: I just remembered that we were running the folding program that analyzes your system profile and had to stop it because of the thermals on the gpus.
  #20 (permalink)
Old August 30, 2010, 04:29 PM
martin_metal_88's Avatar
lol 90 cfm rated at 16 DBs what a great lie from a brand:P maybe at 10 feet of the fan it can be true.
Ask for more
Martin_metal_88
Colenzo : See system spec!
Odysseus : I7 860 @ 3.6Ghz || GA P55-UD5 || G.skill Ripjaws F3-16000 2000Mhz 2X2GB || Coolermaster ATCS 840 || Silverstone Strider plus 850W || WD 640 black - WD 1TB green - Samsung F3 2TB || MSI 5670 1GB Cyclone ||Coolermaster Hyper 212 + ||
NVIDIA Removes Restriction on ATI GPUs with NVIDIA GPUs Processing PhysX burebista Reviews & Articles from the Web 80 May 31, 2010 05:47 PM
ati-nvidia physx hybrid, how to oc nvidia card? cozmosland Video Cards 2 March 21, 2010 11:24 AM
NVIDIA Brings A New Dimension To PC Gaming With NVIDIA 3DTV Play For The Big Screen FiXT Press Releases & Tech News 26 March 16, 2010 07:53 PM
NVIDIA Fermi (GT300) Pictured From NVIDIA GTC FiXT Press Releases & Tech News 22 October 2, 2009 08:04 PM
first time with nvidia.... nvidia or ati? hohohee Video Cards 27 April 27, 2009 08:49 PM
