-   -   GPU-Z only showing x8 PCI-E lanes?? (http://www.hardwarecanucks.com/forum/video-cards/35577-gpu-z-only-showing-x8-pci-e-lanes.html)
homer98 August 25, 2010 08:06 PM
hey all, im a little worried, GPU-Z is showing Bus Interface PCI-E x16 @ x8
What does that mean, why is not not running at the full x16 lanes? any insight would be greatly appreciated. Cheers
SugarJ August 25, 2010 08:10 PM
More info please. What mobo and GPU, and which slot are you running it in?
Do you have a sound card in another PCI-E slot?
homer98 August 25, 2010 08:12 PM
Sorry,
ASUS P6X58D-E
EVGA GTX460
Card is in first PCI-E x16 slot, no other slots are filled up, using onboard mobo sound. no sli, 1 single card.
even when game is running, still showing @ x8.
_dangtx_ August 25, 2010 08:19 PM
either way(one or two) you should have 16x. i dont know that particular board(was thinking p55 but its x58)
http://benchmarkreviews.com/index.ph...1&limitstart=6
ASUS offers three PCI-Express 2.0-compliant ports on the P6X58D-E: the first slot offers 16x link lanes, the second operates at 16x lanes or switches to 8x whenever the third slot is occupied, which also operates at 8x. In a two-card graphics setup using either ATI CrossFire or NVIDIA SLI configuration, the first two PCI-E 2.0 ports operating at 16-lanes per video card offers the most ideal bandwidth.
While adding a third video card for triple-SLI or CrossFireX won't come close to bandwidth saturation and should not see any measure of reduced performance for most video games, there could be a penalty for using that third PCIe slot when SATA6G (Marvell 9123) and USB-3.0 (NEC D720200F1) are enabled. Intel's X58-Express offers 32 total PCI-E 2.0 link lanes reserved for graphics, and the Intel X58 IOH provides an additional four lanes that can be used for graphics or I/O for a total of 36 PCI-Express lanes. More likely uses of those four lanes will be the DMI link, Marvell, and NEC chips, which will share those lanes or borrow as-needed for normal operation.
homer98 August 25, 2010 08:55 PM
yeah, so I should be getting full x16 lanes. Should I try reseating the card in the 2nd PCI-E slot?
SugarJ August 25, 2010 09:15 PM
I'd give that a go. I'm not familiar with that particular board, but there's no jumpers or bios settings to change the PCI-E lanes around is there?
homer98 August 25, 2010 09:22 PM
Hmm, that didnt work, still showed up @x8.
The only jumpers are for overvolts. The only thing in the BIOS is for the 2nd and 3rd PCI-E buses. The manual says the first one will always be x16.
So im thinking that GPU-Z is just not displaying the right info?? is there any other programs that will show that info?
_dangtx_ August 25, 2010 09:33 PM
everest. maybe a bench software. youre not losing much anyway. but it'd be enerving. probably suga is right, bios fiddling.
SugarJ August 25, 2010 09:40 PM
_dangtx_ is correct, the difference in performance has been shown to be minimal with current generation video cards. IIRC it's less than 3%, or likely only 1-2 frames per second.
But I'd be trying to figure out why too. When I had this same issue, it was because I had my sound card in the wrong PCI-E slot, causing my slot 1 to downclock to x8.
homer98 August 25, 2010 09:48 PM
hmm, ok, i wont worry about it too much. maybe try a different program/benchmark to double check. Couldn't find anything in BIOS or manual.
Thanks for the help though, HWinfo is showing same thing as GPU-Z. hmm, it is strange though, might look into it a bit later.
