  #31 (permalink)
Old August 28, 2010, 08:10 AM
homer98's Avatar
Ok, I bought from NCIX. The order was placed August 18th. How should I go about it? try to see what EVGA can do or see what NCIX will do?
  #32 (permalink)
Old August 28, 2010, 08:28 AM
Originally Posted by phantom_jo View Post
It is true that EVGA will try to help anyway they can. But, any reputable shop will exchange directly or at least try to help you fix it if the item has just been bought recently. Compared to conversing with EVGA's customer service trying to do every troubleshooting methods in the book. You also have to consider the duration of it will take to ship both ways.
My point is that if the issue is software or configuration-related then replacing the motherboard will not fix it. You should always try to narrow down the problem before replacing any hardware.
  #33 (permalink)
Old August 28, 2010, 10:56 AM
SugarJ's Avatar
As it's under 30 days, start with talking to NCIX tech support. If they can't resolve it, then an RMA to NCIX is probably in order.
  #34 (permalink)
Old August 28, 2010, 01:03 PM
i think you got some dust in the PCIe slot. i had a problem with my 4890 showing as 4X and after 2 hours diagnosing i just blew out the slot and it showed X16 again. hopefully this is all it is for you
  #35 (permalink)
Old August 28, 2010, 01:10 PM
MittWaffle's Avatar
Well HARDOCP just showed a sli comparison 8vs16x and there is little to no difference ;)!
PCI Express And SLI Scaling: How Many Lanes Do You Need? Luay79 New Builds 1 August 9, 2010 01:47 AM
Running low on PCI lanes Toyoracer Reviews & Articles from the Web 0 March 25, 2010 08:27 PM
looking for PCI [not PCI-E] GPU with at least Shader model 3.0 Psycho-Designs Video Cards 5 March 13, 2010 09:48 AM
Are your GPU clients showing server errors? chrisk HardwareCanucks F@H Team 20 December 26, 2009 11:00 AM
pci-e lanes troubles phantom_jo Troubleshooting 6 May 13, 2009 03:02 PM
