  #61 (permalink)
Old October 9, 2010, 09:11 AM
rjbarker's Avatar
Martin...I take offense to you using the word "stupid"....that comment simply was uncalled for and certainly not necessary (keep it to yourself next time my friend).....read through that Thread I posted "carefully"...us Classy 759 owners are simply looking at options in case the Mobo takes out a few thousand $$ worth of HW.....
btw...Classy 759 NB at 50C ??...please...they're infamous for generating a hell of a lot more heat than that...mine sits between 65 - 70C....(thats with the addition of a Delta 40mm Fan attached to my HS)
As for the Rampage III having "issues"....you know as well as I do that if you Google "any" Mobo you'll find all kinds of "issues" with any of them...I'm still not convinced to go with Giga / Asus or another Classy (3), that will be my decision...!
Martin..I do appreciate the info re: your experience with the Rampage III Extreme, it provides me with more info for making an educated decision on my next Board!
I too will likely contact Evga Support and see what / if I have any options other than purchasing a new Board.....(they're built with Tri SLi capabilities for a reason ;) )
mkultra...
No Evga bashing here at all ....btw...good to know in the event I had to RMA my Chip it wouldn't be a headache...seeing as how you have RMA'd a number of Chips, do you happen to have Intel RMA (Canada) link / Tel #....just in case !
Cheers
Classified Ultra SLi "Procyon"
http://i30.photobucket.com/albums/c3...2/DSC02888.jpg
http://i30.photobucket.com/albums/c3...2/DSC02889.jpg
Evga 4.2 Ghz Club....
  #62 (permalink)
Old October 9, 2010, 09:25 AM
martin_metal_88's Avatar
Originally Posted by rjbarker View Post
Honestly guys...you all know I am an avid Evga customer, but in light of this I may certainly give the Asus Rampage III Extreme a go :)
btw my Classy LE # is 0525...
EVGA X58 759 Classifed Limited Edition #551 down... going to get an ASUS....=/
Sorry Rj, wans't mean to hurt you. At all my comment was not quite weel written. I explain, The stupid attitude was not point to you but to anyone who would say that hey I have a possible issue I change brand! You understand the fact that if you do time every time you have a issue you will fast do the whole turn of the market I also have a little something against asus after working with them for long so to hear you putting the idea of changing to them chock me a bit Also, about the temp I have no idea for the Classified since I never work with it but comparing the Asus to few GA and MSI damn the heat delta is pretty huge.
Once again sorry if it was offensive hope you'll pardon me one day
Martin
/[ stop thread crapping]/
Ask for more
Martin_metal_88
Colenzo : See system spec!
Odysseus : I7 860 @ 3.6Ghz || GA P55-UD5 || G.skill Ripjaws F3-16000 2000Mhz 2X2GB || Coolermaster ATCS 840 || Silverstone Strider plus 850W || WD 640 black - WD 1TB green - Samsung F3 2TB || MSI 5670 1GB Cyclone ||Coolermaster Hyper 212 + ||
  #63 (permalink)
Old October 9, 2010, 09:34 AM
i was saying baching because idk what you can ask more from evga.....i can't see any company throwing out an entire series of mobo because of a problem affecting what 1% of users?
no tel number sorry, since i speak french i usually deal in email....it's easier for me
i didn't say "chip" tho i said rma
i only sent 1 cpu back but it was still on the 30day return so store took care of that, cpu are usually the strongest part in a PC....i don't count how many rams kit i've rma to corsair/ocz, or vga to msi/evga and never had problem with heavily overclocked parts.
  #64 (permalink)
Old October 9, 2010, 09:42 AM
Originally Posted by encorp View Post
Did anyone bother looking into the heat tolerances on the plastic material used in the connectors?
I'm not sure that overdraw would cause this; since usually it fries the wires throughout or at least through it's housing - somewhere. The metal connectors will never just fry like this.
I'm thinking cheap plastic is to blame in some cases.
It's not the plastic. The pins in the connector on the motherboard are not making proper contact with the sleeves in the PSU connector. This increases the resistance of the connection which raises the temperature. At higher loads, the temperature becomes too high and the damage is caused.
  #65 (permalink)
Old October 9, 2010, 09:46 AM
sswilson's Avatar
Considering how old the ATX standard is, I don't think anybody ever conceived folks wanting to run 4X cards on the PCIe slots and that's where the issue ultimately lays (lies? ;) ).
I don't have the 790FX board any more so I had to have a look at images from reviews, but I was surprised to see that it didn't have an extra Molex for the motherboard. I suspect that's the only "fix" for the problem, and hopefully motherboard manufacturers who want to produce 4X PCIe boards will take heed and design that into future motherboards.
  #66 (permalink)
Old October 9, 2010, 10:38 AM
so basically, if you have the board in question, call up evga and tell them youre going to populate all pci-e slots thus warrant a free upgrade before it surely blows? :)
edit : when they put 4 pci-e slots or 2 or 3 on the one board, they have to look at the biggest baddest gpu in existence and what power it draws, then multiply that by the said number of slots and see, at least theoretically, if it is going to be ok.
i still dont get it how 7 years old boards have a molex for two pci-e lanes whereas 4 slotted boards these days don't....
  #67 (permalink)
Old October 9, 2010, 12:04 PM
rjbarker's Avatar
Martin.......no worries...chaulk it up as 'shvtty Internet Comms" :)
Dan.....that is what I think I'd like to see and what I'll be contacting Evga about....is an RMA to have them solder the appropriate Molex Connector onto the Board, someone over at Evga Forums has a step by step on how to do this, but I'm not going to void the Lifetime Warranty nor should I be expected to. Evga knows perfectly well thier is a potential serious problem when loading up all 3 PCIE Slots and they know the "fix" is to install the additional Molex connector, so take our Boards and make em right.
I'll likely replace the Board anyhow, but for re-sale would be better with the Molex socket onboard.
  #68 (permalink)
Old October 9, 2010, 12:26 PM
r0bc's Avatar
I'm not going to worry about it, If it happens I'll deal with it.
  #69 (permalink)
Old October 11, 2010, 12:45 PM
OH wow, time to reconsider using GTX480 in sli.
  #70 (permalink)
Old December 16, 2010, 12:25 PM
Sagath's Avatar
Just an update to this issue; EVGA has gone above and beyond again; Update PLEASE (pci-e adapter/molex power fix)
Now, obviously this is just a 'band-aid' solution to an onboard molex, but at least its a solution! I dont see ASUS or GB doing this sort of thing with their no-molex boards :D However, this EVGA solution will work in their boards too :P
Originally Posted by Lpfan4ever View Post
AKG shot the hamsters, and then Perineum drove his Mustang with summer tires into the server.
GTX 480: To SLI Or Not To SLI, That Is The Question? TheGregster76 Video Cards 22 June 15, 2010 05:47 PM
[FS] EVGA E760 Classified, i7-920 DO, Corsair Dominator MarkOne Buy/Sell & Trade 22 March 1, 2010 07:49 PM
[FS] Evga Classified E760, WC stuff... others Dar_T Buy/Sell & Trade 4 October 26, 2009 01:40 PM
EVGA X58 E760 Classified vs E758-A1 Georgian CPU's and Motherboards 4 October 18, 2009 12:58 PM
EVGA Announces GTX 285 Classified and X58 Classified 4-Way SLI Motherboard voklskier4452 Press Releases & Tech News 38 September 9, 2009 03:17 PM
