Old August 25, 2010, 07:08 PM
scruff's Avatar
In my experiance in control wiring ,the only time we see that kind of dammage is if there is a short some where or bad connection at the pins . over current draw will usually show up as melted wire insulation not melted pins.
Old August 25, 2010, 07:16 PM
LionRed's Avatar
I can assure you these connectors were firmly connected into the socket.
What does a wire look like when it is plainly drawing too much power?
They say you can tell how rich a man's life has been, by how many dogs he has had in it.
RIP Kiwi - Oct 19th/05 - April 18th/11, you will always be our puppy!
Old August 25, 2010, 07:24 PM
scruff's Avatar
The insulation will usually be slightly discoloured and saggy or burned and crispy depending how long the over current was able to continue before any safety fuses or breakers tripped. two plastic connectors put together does not mean a good connection on the pins unfortunatelly. the damage sure looks like a short to me (seen it way too many times)
Old August 25, 2010, 07:26 PM
SugarJ's Avatar
Black. As in it catches fire.
I agree that those melted connectors look like a bad/shorting connection, rather than an overcurrent situation. It could be the result of a bad connector, not the way it was inserted.
Old August 25, 2010, 07:32 PM
LionRed's Avatar
Well I guess they should be easy to crimp down a bit to get a better connection.
Old August 25, 2010, 07:40 PM
SugarJ's Avatar
Yup. Easy access now.
Notice how they are spread apart a bit at the end? That's probably what the problem was.
Old August 25, 2010, 07:42 PM
ouch indeed. rma on both or just the mobo?
it mustve taken a bit of heat to do that
and no way you need to cool down cables, i mean what the fold?
Old August 25, 2010, 07:47 PM
SugarJ's Avatar
How does the mobo socket look? Have you tried another PSU to make sure it boots?
  #19 (permalink)
Old August 25, 2010, 07:50 PM
LionRed's Avatar
The top yellow wire...doesn't it look a little discolored just before it goes into the plastic covering?
I am still going to look into RMA'n the MB...seems I am not alone. If I am stuck with the MB....then it is an area I will have to monitor. Least I am aware of it now.
System is working fine now....I clear the melted plastic out of MB connection..system booted/works fine. But the GPU's haven't been stressed since the melted connector. The female connector on the MB has not melting...just some stuff from the PS connector (which I cleared out).
  #20 (permalink)
Old August 25, 2010, 07:54 PM
SugarJ's Avatar
Yes, the wire is discolored near the sparking connection. If it was overcurrented, the whole wire would look like that, or worse.
GTX 480: To SLI Or Not To SLI, That Is The Question? TheGregster76 Video Cards 22 June 15, 2010 05:47 PM
[FS] EVGA E760 Classified, i7-920 DO, Corsair Dominator MarkOne Buy/Sell & Trade 22 March 1, 2010 08:49 PM
[FS] Evga Classified E760, WC stuff... others Dar_T Buy/Sell & Trade 4 October 26, 2009 01:40 PM
EVGA X58 E760 Classified vs E758-A1 Georgian CPU's and Motherboards 4 October 18, 2009 12:58 PM
EVGA Announces GTX 285 Classified and X58 Classified 4-Way SLI Motherboard voklskier4452 Press Releases & Tech News 38 September 9, 2009 03:17 PM
