Old August 24, 2010, 05:35 PM
MpG's Avatar
MpG MpG is offline
Originally Posted by Zero82z View Post
Maybe one of the factory workers got a little excited while assembling your card...
Maybe this is Foxconn's latest strategy to improve workplace conditions.
Old August 24, 2010, 05:38 PM
magictorch's Avatar
Does the area around the whitening get pretty hot? I'd also stab at a heat issue causing some sort of "layer?" on the PCB to react with the solder points.
Old August 24, 2010, 06:39 PM
Dr_BenD_over's Avatar
Fallen Folder
By the looks of it, that's some sort of residue from whatever they masked off the through-hole component holes off with when they ran the SMT. (Surface mount and through-hole components are soldered by different processes) It shouldn't cause any issues.
All's well that's Haswell
Old August 24, 2010, 06:58 PM
stoanee's Avatar
or couldn't find a mirror..
heatware
Old August 24, 2010, 07:11 PM
gingerbee's Avatar
Very good pint i missed that it's all the soldier through point not surface
Old August 24, 2010, 10:28 PM
JD JD is offline
My HD5870 has this too. I figured it was residue from the manufacturing. GPU has been running fine so I see no need to worry.
Old September 14, 2010, 08:08 PM
Just got an EVGA 460 in the mail today and it has a bunch of sticky crap around that area.
looking for white colour case importpsycho Cases 15 June 6, 2010 03:44 AM
WHITE HELL _dangtx_ Off Topic 26 January 29, 2010 03:26 PM
White Sleeving Phobia Power Supplies 2 July 5, 2009 12:26 PM
Addict in the White House! Gellidius Off Topic 11 June 24, 2009 05:43 PM
[FS] Socket A stuff + AGP card + PSU + LCD + lots of stuff ebdoradz Buy/Sell & Trade 13 June 14, 2009 09:14 PM
