Old December 4, 2007, 09:19 AM
3.0charlie's Avatar
Question Single slot bracket?
One of my clients wants to install a 8800GTS in a Dell case. The problem is that the dual slot bracket cannot be used - it's fouling against the case structure. And he wants to keep the original bracket intact, ie. not cut it and remove the vent section.
Any ideas where I could find a single slot replacement bracket for the 8800GTS (DVI-DVI-Svideo)?
Thanks,
John
Hydro-Quebec is salivating...
Old December 4, 2007, 10:37 AM
MpG's Avatar
MpG MpG is offline
I've seen these available at Dangerden and PPC, if that's what you're looking for. They're normally used with waterblocks, so if you're not WC-ing the card, I assume you'll do something about the heat evacuation?
Old December 4, 2007, 10:40 AM
Thanks,
John
Unless you go watercooling there is nothing you can do. All heatsinks for that video card will take up more space than the stock one does.
Old December 4, 2007, 10:41 AM
3.0charlie's Avatar
Thanks, that's exactly it. It's an air-cooled card in a Dell case. But I can't use the dual-slot bracket, since it is fouling with the case.
Old December 4, 2007, 10:45 AM
3.0charlie's Avatar
I'm not talking about the heatsink, it's the slot bracket fouling the case.
Old December 4, 2007, 10:50 AM
Doesn't the bracket help keep the air flowing outside the case and not inside tho?
Old December 4, 2007, 10:52 AM
"Quote This..."
But the second slot bracket is where the air exhausts from the heatsink and out of the case. Make sure you remove the slot cover from the case on the second slot.
Old December 4, 2007, 11:45 AM
3.0charlie's Avatar
The existing dual-slot bracket is removed, to allow the installation of the card; one of the upper blank slot bracket has been removed and replaced by a grilled one I had available.
That Dell desktop has the motherboard inverted, and the PCI-E slot is the very first one. Hot air exhaust is not a problem.
John
Old December 4, 2007, 02:42 PM
I got one with an NV Silencer. I'll see if I kept it or gave it to the person I sold the card with it to.
Maybe NCIX has them somewhere obscure on their website?
Old December 4, 2007, 03:47 PM
3.0charlie's Avatar
I have checked all my favorites and found nothing, except for the 2 sites mentionned in the 1st reply.
Can't get pins into X Bracket for Thermalright Ultra 90 Pylonman Troubleshooting 3 March 10, 2008 07:42 PM
16 dim slot server board of ATX size? elninio CPU's and Motherboards 9 February 17, 2008 11:33 PM
Dual CPU slot board? 3.0charlie CPU's and Motherboards 19 February 1, 2008 08:30 AM
[For Sale/Trade] iMac G3 Indigo Case (Slot Loading) ~pcwiz Buy/Sell & Trade 3 January 4, 2008 03:45 PM
Video card hook up slot mailaw Video Cards 6 July 26, 2007 07:58 AM
