-   -   Asus 5870 ROG Matrix Platinum & GPU question. (http://www.hardwarecanucks.com/forum/video-cards/35417-asus-5870-rog-matrix-platinum-gpu-question.html)
glock19er August 20, 2010 05:16 PM
Hello. My brother is selling me his Asus 5870 ROG Matrix Platinum edition card and I have a question about the two 8 pin connections. My PSU is a Silverstone DA-1000 which has 4x6 pin PCIE connectors and 2x8 pin PCIE connectors. The Asus requires 2x8 pin connections and it comes with two 6pin to 8pin connectors. Would it be better to use two 6pin to 8pin connectors that come with the card or just use the two 8pin connector cables that come with the Silverstone?
Arinoth August 20, 2010 05:20 PM
Doesn't really matter, i typically stick with least amount of 'cables' so i would just use the two 8-pin connectors from the PSU, but you shouldnt have an issue using the 6 to 8 adapters either
glock19er August 20, 2010 05:53 PM
Thanks Arinoth. I appreciate the info.
