<~----> GPU Upgrade time - Hardware Canucks
Old August 19, 2010, 11:19 AM
Cptn Vortex's Avatar
Default GPU Upgrade time
So, time to get rid of my 9800GX2, its showing its age.
Keeping in mind I am not going to upgrade my current board/CPU/RAM, whats the best bang for the buck?
My board will only do Xfire, so I am thinking 3 x 5770's?
Pretty much only playing BC2. 1080p Screen.
Thoughts?
The Vortex H20
MSI Z77A-GD65
Intel i7 3770K @ 4.6GHZ 1.28v
Galaxy GTX 680 @ 1241MHZ
8GB Mushkin Blackline 1600MHZ 9-9-9-24 1.5v
Asus Xonar Essence STX
OCZ Z-Series GOLD 850W
2 x 128GB Corsair Force GT SATA3 SSD RAID0 :)
Acheiva Shimian Q270 Lite 2560x1440
Benq W500 Pojector.
Watercooling:
EK Supreme HF, EK FC GTX 680 Block, MCR320+Gelid Silent 12 Push/Pull, DD Pump, EK Multioption 100ml Res, EK Coolstream XT 220 RAD Gelid Wings Push/Pull.
Old August 19, 2010, 11:22 AM
SugarJ's Avatar
Single GTX470, works great on my 24", and way cheaper that 3x 5770's. NCIX has the Zotac one on for $270 after MIR. http://ncix.com/products/index.php?s...c&promoid=1088
Old August 19, 2010, 11:34 AM
jcmaz's Avatar
I would either get a MSI 465 **Unlocked** by Linus or an EVGA GTX 470.
I find that the ATI drivers give the most problems with older games and some compatibility issues with some current games (BFBC2), with my 4850...
If you wish to wait a bit, i recommend a video card with the full GF104 core.
-Plato
Old August 19, 2010, 11:52 AM
SugarJ's Avatar
The unlocked 465 is actually more expensive than the 470 I linked. :)
Old August 19, 2010, 01:02 PM
What is your budget?
The 470 seems like a good bet... especially at 270$!
Old August 19, 2010, 02:18 PM
The MSI GTX 465 unlocked is intriguing only because it comes with 3 games, metro 2033, just cause 2, and dark void/RE5/SF4.
Old August 19, 2010, 03:46 PM
If it isn't an urgent upgrade, ATI is releasing their 6000 series cards this fall I believe. Maybe wait and see what is just around the corner...
Old August 19, 2010, 07:47 PM
Yea, for upgrade, I want to gain Alot. Single card wont cut it for me.... I went from dual 8800GTX in SLI, then this 9800 GX2, so its time for most power out of about $450. Really, if you can find better results than 3 x 5770's in Bad Company 2, for under $450, I'm all ears. My board wont do SLI so I am kinda stuck with either a single nVidia card, or a crossfire setup.
The Vortex H20
MSI Z77A-GD65
Benq W500 Pojector.
Watercooling:
Old August 19, 2010, 08:07 PM
since you waited, probably a good idea to wait till at least nv answers the ati refresh half way there coming cards :)
Old August 19, 2010, 08:20 PM
rjbarker's Avatar
^^^ Yep your "limited" thats for sure...no Sli....bummer...what about a couple of 5850's......or single 480......
Time for an upgrade .. maybe? implosion222 Video Cards 22 August 13, 2010 11:38 PM
Upgrade time! D4ng3r New Builds 11 May 10, 2010 09:59 PM
Upgrade time - what to keep?? Urotsukidoji New Builds 69 November 20, 2008 03:56 PM
It's time to upgrade... 3.0charlie New Builds 9 July 4, 2008 07:43 PM
time to upgrade monsterp CPU's and Motherboards 6 October 30, 2007 08:04 PM
