Old August 19, 2010, 08:43 PM
headsh0t's Avatar
Originally Posted by rjbarker View Post
^^^ Yep your "limited" thats for sure...no Sli....bummer...what about a couple of 5850's......or single 480......
3 5770's would be all of that. Well ok the 5850s would beat it but cheapest one I can find is just under $300. Go for the 5770's bro if that's what your set on cause clearly there isnt anything else that will suit your needs. Only thing is is that is a bunch of extra power... but it's probably equal to a 480 so no big deal LOL jk
Old August 19, 2010, 09:23 PM
rjbarker's Avatar
Vortex....some games seem to scale well ....others not so grand.....likely your only decent option...
http://www.guru3d.com/article/radeon...-review-test/1
Firestrike Extreme: 21.452
MARK 11: 32.530
Old August 20, 2010, 02:50 PM
Cptn Vortex's Avatar
Will investigate further....thanks lol!
The Vortex H20
Asus X99-E WS/USB 3.0
i7-5820K
3 x GTX 1070
4x4GB Corsair LPX 2666MHZ
OCZ Z-Series GOLD 850W
HP OMEN 32 1440p 75hz
Benq W1070 Pojector.
Watercooling:
Old August 20, 2010, 03:38 PM
JayDeeHobbit's Avatar
I see you have a foling tag Cptn = nVidia if you want folding to be part of the fun.
I still love my GTX260 but if I were going to upgrade it would be the GTX460 for me.
The GTX470 is on sale, true, but the lower power requirements and performance ratio of the GTX460 make it a sweet spot Gamer/Folder card just like my GTX260 is/was.
"Try looking into that place where you dare not look!
You'll find me there, staring out at you!" - Frank Herbert
Old August 20, 2010, 04:36 PM
headsh0t's Avatar
A GTX460 won't do for the performance he is looking for.
Old August 20, 2010, 07:24 PM
im thinking oc'ing properly a 460 should get him there. http://tpucdn.com/reviews/Zotac/GeFo...es/perf_oc.gif , http://tpucdn.com/reviews/Zotac/GeFo...es/perfrel.gif
and power figures below the 470 even when oc'ed, from what is reported around the web. this without touching vgpu of course.
best thing,but a bit painful, would be to rid himself of the gx2 till it still holds some value.
trouble is, even a 480 cant do maxed out anything at his preferred resolution. might have to sit this one out for another gen..kinda repeating meself :p
Time for an upgrade .. maybe? implosion222 Video Cards 22 August 13, 2010 11:38 PM
Upgrade time! D4ng3r New Builds 11 May 10, 2010 09:59 PM
Upgrade time - what to keep?? Urotsukidoji New Builds 69 November 20, 2008 04:56 PM
It's time to upgrade... 3.0charlie New Builds 9 July 4, 2008 07:43 PM
time to upgrade monsterp CPU's and Motherboards 6 October 30, 2007 08:04 PM
