Old August 29, 2010, 04:43 AM
fishingfanatic's Avatar
Smile Video Cards
Good choice for a gpu, EVGA having great warranty and support. I own the HAF X and have a 480. If you can install a fan behind the gpu, it'll run even cooler. The HAF has a shroud that comes with the case and I can put my hand on the card after running for an hour.
Old August 29, 2010, 08:49 AM
rjbarker's Avatar
1. Fermi 470 / 480's run hot...get used to it, no biggie, with proper air flow there should be no ill effects.
2. With Evga's "AR" Lifetime Warranty and Forum Support / Customer Service the choice is a no brainer.
3. All Fermi 470 / 480's OC like friggin crazy......just watch te Temps and set-up Fan Profiles, Ive had my 480's at 850 / 1700 / 2100 without Artifacts.
4. Yes, you can Mod your Air Flow Bracket yourself...but why would you fvck with your Warranty and void it? (if the Card doesn't come with the High Flow Air Bracket...Evga is offering them to Registered Card owners for free..shipping to Canuckland is $5).
Firestrike Extreme: 21.452
MARK 11: 32.530
Old September 1, 2010, 04:21 PM
MittWaffle's Avatar
Well the EVGA 470..
Voltage .950
Vesus Asus model
Voltage .925
Not that bad, but I am able to run 800/1600/1750 with 1.025 which is excellent, my asus needed alot of juice to get OCCT stable (1.075-1.087).
I havent ran it higher; no games that really need the extra boost. But I ordered the EVGA Hi-flow bracket this week (just pay s/h), and also a 30 dollar sample of some IC Diamond i'm going to apply aswell.
If the temps drop 2-5c i'll try to get the 850's-875's stable.
Old September 2, 2010, 02:38 PM
It would be nice to see it run cooler, but that's a great overclock. I'd probably try replacing TIM or checking into the high-flow bracket before returning that particular card.
Review Units FS. SKYMTL's Great GPU Sale 2017 - Part 1 SKYMTL Buy/Sell & Trade 1066 December 30, 2017 09:52 AM
[WTB] GTX 470 stock cooler 1 or 2 kfcheung Buy/Sell & Trade 4 July 13, 2010 12:47 AM
EVGA Geforce GTX 470 SC+ ? Alwaysrun Video Cards 4 June 15, 2010 04:33 PM
5870 Vapor or EVGA 470+ and warranty question FreeKnight Video Cards 6 May 28, 2010 10:15 AM
My computer is bigger and run cooler than all your's dataxpert Off Topic 10 April 30, 2009 04:00 PM
