Originally Posted by technix For the money, would you guys say a GTX 460 for $230 is better than the HD 5770 @ $140 - $160?
'Doesn't look like video cards are dropping in price much? |
I'd say it depends on what you're using the cards for. The 460 is almost twice the GPU... for almost twice the price. They're probably roughly the same cost/performance ratio, but the 460 is the faster of the two of course.
If you're looking for a cost effective, great performing GPU, and you still want to keep the volume/temps down, I'd consider the MSI 460 Cyclone. You can get the 768MB version for $220.
If you want a budget minded GPU for an HTPC style rig that is also a capable entry level gamer, then grab a 5770.
*EDIT*
If you provide info on the rest of your build and the cards intended usage, you'll likely get a more relevant answer.
