Old August 16, 2010, 10:57 PM
jcmaz's Avatar
Default Baking video card Q's
Hey HWC,
I have an overheated 8500GT that does not display any image but posts.
So what are my chances of reviving my 8500GT? Will the baking process even work for overheated video cards?
Thanks for the help,
Jcmaz
-Plato
Old August 16, 2010, 11:03 PM
only if you use presidents choice shake' n bake..or since it overheated ,try freezing it.. jk.
actually if it doesn't work atm. never hurts to try..
ps. i know useless post going for a laugh tho
http://valid.canardpc.com/show_oc.php?id=932179
"Be so good at what you do that you cant be ignored"
Old August 16, 2010, 11:14 PM
shayan288's Avatar
Really all what the baking does, is reflow the solder. Often, that all an overheating card needs. So I say GO FOR IT!
The 288
Q9550 E0 stepping @ 4Ghz
Gigabyte EP45 UD3P
G.Skill pc2 8500 1066mhz RAM
Western Digital 250gb
Antec 1200
XFX HD5970
Steelseries Xai Laser Mouse
Windows 7 Ultimate x64
Old August 16, 2010, 11:35 PM
There's no way to tell if it'll work or not other than actually trying it. You've got nothing to lose, so you may as well.
Old August 17, 2010, 12:21 AM
dustin1706's Avatar
My 8800GTX would power up, the fan would spin, but no display. I preheated to 385f took off the cooler, set it on some balls of tinfoil and put it in for about 10 minutes. Took it out, let it cool and it has worked great ever since.
Old August 17, 2010, 06:18 AM
Perineum's Avatar
The only thing to worry about is the capacitors, they tend to blow up when heated too long.
By "overheated" if you mean the card was run with the HS fan not running then I think you're going to have limited success.
Anyway, in my experience I wouldn't go over 5 minutes at 425F. You can always try it more than once but you can't do the reverse.
Old August 17, 2010, 07:27 AM
jcmaz's Avatar
According to my friend, the heatsink fell off while the computer was on overnight...
Anywho, i'll try it anyway :)
-Plato
Old August 17, 2010, 08:03 AM
Realityshift's Avatar
Wonder if this would save my 4870x2... posts, displays but once I hit desktop its artifacted beyond recognition.
EDIT: how on earth does a heatsink fall off? Screws ftw
The Builders Hammer
Old August 17, 2010, 08:15 AM
jcmaz's Avatar
I honestly don't know. It is only of those push pin style screws. Plus, only 2 of them secure the heatsink on.
I have looked at the caps, they don't have the bulged look so i guess they are ok for baking.
-Plato
Old August 17, 2010, 09:35 AM
I read that for the 8500 cards you use 385 for 7-8 minutes, noticed a few of them being done on the Overclock.uk forums. Gonna try my 4870x2 this set off, would love to get that card back up and running.
The Builders Hammer
Sappire 4870X2 Baking Process AmuseMe Case Mods, Worklog & Gallery 46 July 17, 2010 04:04 PM
[WTB] Sound card and wc video card hausner Buy/Sell & Trade 17 August 11, 2009 01:59 PM
WTB: Video Card/Sound Card/Hard drive - Look here if u gotz some ! Flintblade Buy/Sell & Trade 4 December 4, 2008 10:27 PM
Video Card memory 512 Available video memory 1268 mb? TwystedMonkey Troubleshooting 4 August 24, 2008 06:07 PM
WTB PCI-E Video card with Video out Taichan Buy/Sell & Trade 0 June 9, 2008 08:17 PM
