Old August 11, 2010, 09:44 PM
SKYMTL's Avatar
HardwareCanuck Review Editor
Default XFX Radeon HD 5770 1GB Single Slot Review Comment Thread
There are countless HD 5770 cards on the market these days but there has been very little to distinguish one from another. XFX has decided to break with the pack and has released a single slot HD 5770 which should appeal to people looking for compact, well-heeled performance. In this review, we see if it can deliver....
[ Read full article ]
Old August 11, 2010, 09:52 PM
very nice but where does the air go again?
looks amiss to me concept wise, for the exception of the slim profile cooler.
http://images.hardwarecanucks.com/im...LE-SLOT-10.jpg
Old August 11, 2010, 09:57 PM
jcmaz's Avatar
The air goes to the hard drive???
On a side note, XFX does email you an HDMI - DVI adapter if you ask them, for free too :)
ďWise men speak because they have something to say; Fools because they have to say something.Ē
-Plato
Old August 11, 2010, 10:08 PM
SKYMTL's Avatar
If you have ANY proper airflow in your case, the minimum amount of heat coming from the card will not cause an issue at all.
Old August 11, 2010, 10:09 PM
FlyingFish's Avatar
How does it compare to a regular size 5770? More heat?
Old August 11, 2010, 10:11 PM
SKYMTL's Avatar
Same core and memory; same TDP.
Old August 11, 2010, 10:15 PM
hmm.ok. so at full blast air coming back in the case doesnt affect much because of said low-ish tdp? :)
Old August 11, 2010, 11:17 PM
Holy shit, they can do that with emails now?!
Old August 12, 2010, 04:40 AM
fishingfanatic's Avatar
Smile Video Cards
For a htpc I think it's a good choice. For a main system, imho the 460 wins hands down. As mentioned, I don't believe thermals should be an issue provided you have decent airflow which is pretty much needed with newer cards anyway. Another great review SKY!!!
Old August 12, 2010, 07:36 AM
martin_metal_88's Avatar
Good find I seriously never saw a small fan like that being silent? For sure these card are low power and perform cold but if the fan start spin around probably 40% it will probably makea little vaccum noise that would make me throw it out the window. Also, by knowing XFX for long, I think it's not a good idea to shrink the PCB and remove some thing on it, every single time they have done it the card always lose some quality. After people ask why they are cheaper on price...
XFX Radeon HD 5830 1GB GDDR5 Review Comment Thread SKYMTL Video Cards 23 March 20, 2010 05:13 PM
Sapphire Radeon HD5570 1GB DDR3 Single & Crossfire Review Comment Thread SKYMTL Video Cards 16 February 9, 2010 07:53 PM
XFX Radeon HD 5850 1GB GDDR5 Review Comment Thread SKYMTL Video Cards 33 November 16, 2009 08:57 AM
