Old August 9, 2010, 06:33 PM
Hitikiro's Avatar
Default 470GTX and 8800GT for Physx on 520W PSU
So I managed to snag the MSI N465GTX GE Twin Frozr at a good price and I am planning to unlock it to a 470GTX. I don't plan on upgrading my C2D setup so whatever is in my signature right now is what I will be running.
Now my question is if I will be able to run that 470GTX (potentially overclocked) with a 8800GT as a dedicated Physx card on my Corsair HX520? I've checked out eXtreme Outer Vision - eXtreme tools for computer enthusiasts PSU calculator and it suggests that I will need ~458W just to run this setup.
If you guys can give me some better insight to see if I am able to run this setup up or just run the 470GTX on its own. Thanks~
Intel Q9550 @ 3.95ghz (1.32v) | Abit IP35 Pro "Snake" | 4 GB Kingston HyperX T1 PC2-8500 | Thermalright Ultra 120 Extreme w/2 X NF-S12B | MSI 465GTX GE (unlocked to 470GTX) | Corsair HX520 PSU | Boot Drive: OCZ Vertex 2 60GB SSD | Storage: Seagate 500GB HDD | Antec P182 Case | 3 Yate Loon DS12L (undervolted) | 2 x Pioneer DVR-212D | Samsung 226BW
Old August 9, 2010, 06:54 PM
rjbarker's Avatar
Personally, I would run only the 465...any "gains" in PhysX with the 8800 GT will be negligible (what few PhysX games that are out their recommend a 9800GTX+ as entry level PhysX Card).....although you should be fine to run both with your HX 520......
Classified Ultra SLi "Procyon"
http://i30.photobucket.com/albums/c3...2/DSC02888.jpg
http://i30.photobucket.com/albums/c3...2/DSC02889.jpg
Evga 4.2 Ghz Club....
Old August 9, 2010, 07:03 PM
Not a good idea.
Old August 9, 2010, 07:12 PM
Arinoth's Avatar
You'll see little to no gain especially with your CPU as the bottleneck
Old August 9, 2010, 07:39 PM
the gtx 4 series are quite the leap, so as per above unless youre maxing it out, you may get a few fps. try it, see what gives.
and if everything is stock, it should be ok-ish :)
Old August 9, 2010, 08:19 PM
near pointless, and you don't really have enough juice.
Old August 10, 2010, 10:37 AM
Hitikiro's Avatar
Well thanks for some insight.. I guess I will just have to test it out and see.
Old August 10, 2010, 01:34 PM
I personnally went from a similar spec system (E3110, 8800Gt, 500W Fortron Bluestorm Psu) and got myself a GTX460. The PC shuts down when using max power... so I don't know about you running dual cards on such a system.
I would try it, but expect a PSU upgrade needed.
Also, what are you doing with 2Gb of Ram? Suggestion, get 2 more, especilly if you are running a 64 bit OS, you will see a great difference!
Old August 10, 2010, 04:17 PM
Hitikiro's Avatar
I am still running Windows XP 32-bit.
using a 8800gt for physx only with my xfx 4890 winnipegm Video Cards 20 August 9, 2009 11:50 AM
[FS] 8800GT @80, Koolance 8800GT waterblock, XFX680i LT @70, ATI 1900XTX, AMD Opteron 144 pakultra Buy/Sell & Trade 12 January 28, 2009 08:42 PM
8800GT SLI on my old PSU? Fracture Power Supplies 1 September 15, 2008 06:45 PM
Newbie question: XFX 8800gt XXX vs. eVGA 8800gt NorthernPike Video Cards 1 July 22, 2008 07:12 PM
is 520W enough? (it's the fault of the Q6600) nico Power Supplies 5 July 26, 2007 11:13 AM
