<~----> 460 sli - Hardware Canucks
Old August 8, 2010, 12:37 PM
Question 460 sli
what power supply is good for 460s in sli. is 850 enough?? like the antec tpq?
i plan on overclocking both the cards and the cpu as far as i can get them.
Old August 8, 2010, 12:51 PM
lowfat's Avatar
850W is plenty enough.
Old August 8, 2010, 12:55 PM
http://tpucdn.com/reviews/MSI/GeForc...er_maximum.gif
times two at stock
add maybe 50-75 watts for each card, hel ladd 100 watts for each card mad oc's wise(but i dont think youll get there not without pushing mad voltages)
and even a decent 600 will do.(that gives 600 on the 12v)
Old August 8, 2010, 01:14 PM
stoanee's Avatar
What cpu?
Free ground shipping-NCIX.com - Buy Corsair TX650W 650W ATX 12V 52A 24PIN ATX Power Supply Active PFC 120MM Fan - CMPSU-650TX In Canada.
heatware
Old August 8, 2010, 05:29 PM
fishingfanatic's Avatar
Smile Video Cards
Good choice of cards. The 650 should be enough, but I might consider the 750 for extra leeway for upgrading your gpus later. For cpu, the 930 is a good choice from Intel, while the 1055 is good for AMD. It really depends on what you'll be doing. If you get the 965 from AMD now you can move up to the 1055 later.
NVIDIA GeForce GTX 460 1GB & GTX 460 768MB Review Comment Thread SKYMTL Video Cards 126 August 20, 2010 10:01 AM
EVGA GTX 460 768MB Superclocked Single & SLI Review Comment Thread SKYMTL Video Cards 16 July 16, 2010 05:19 AM
Tri SLI, Quad SLI, SLI comparisons with 9800GTS, GX2 Babrbarossa Reviews & Articles from the Web 3 March 31, 2008 02:32 PM
