Old August 5, 2010, 11:36 PM
somethings really weird there.
load up a live cd and run 3dgears. google it.
Old August 5, 2010, 11:45 PM
I might be able to give that a try, hopefully soon. Honestly I wish it was something easy and that I was just being an idiot. But for the life of me I just can't figure it out. Especially earlier when I had it running and ran 3DMark06 start to finish without a hiccup at all. The card was burning hot to the touch (the heatsink at least) but still within normal ranges based on CCC's temp gauge. I turn the PC off, connect a power cable to the case's connection for the shiny red lights. Turn it back on and more crashes. Power off, remove cable connecting to case lights and more crashes!
I need a crying/sobbing emoticon...
Old August 6, 2010, 05:07 AM
Ain't that just the weirdest thing. so both the 5770 and 4890 crash, but the GTS 250 doesnt?
maybe you should just completely wipe your hard drive and start everything on the software side anew (if you haven't already) - otherwise I'm out of ideas. It does sound more software though. (sorry about the RAM suggestion, didn't realize you ran another card in there for that amount of time)
Old August 6, 2010, 07:33 AM
jcmaz's Avatar
Does it go into Safe mode with the ATI cards?
-Plato
Old August 6, 2010, 07:48 AM
The 5770 does not crash, he has tried TWO 4890's and both of them have crashed but that same 4890 worked in a different rig.
4890 X2 still worth it? btecanada Video Cards 5 July 14, 2010 10:04 PM
Value of an ASUS 4890 p3t3rson Video Cards 6 February 11, 2010 01:13 PM
OC 4890 DragonFlame Video Cards 1 September 1, 2009 08:44 PM
Toxic HD 4890 or Vapor-X HD 4890 AmuseMe Video Cards 10 July 20, 2009 03:54 AM
OCing a 4890... Z Overlord Overclocking, Tweaking and Benchmarking 8 July 7, 2009 09:33 AM
