-   -   5870 vs 480 for 2560x1600? (http://www.hardwarecanucks.com/forum/video-cards/34327-5870-vs-480-2560x1600.html)
oblisk July 18, 2010 04:24 AM
I currently have a 4870x2, and Crossfire is really bugging me. I want to upgrade to a single GPU solution.
I only game at 2560x1600, and I would like to know what the best choice is. The 480 is more powerful, a $100 more expensive. Is it worth jumping from 4870x2 to the 480? Or should I get on the less powerful 5870?
My cpu is a q9550 at 3.7. How much big of a bottleneck would this be?
The RealRollo July 18, 2010 04:43 AM
I'd say the GTX480. Your 4870X2 has pretty similar power/heat/noise, so you're used to that. The only 5870s that are $100 cheaper than 480s have 50% less RAM, which can come into play at your 25X16 resolution.
If you can order from newegg, they have a MSI 480 for $439 shipped that includes Just Cause 2.
Newegg.com - MSI N480GTX-M2D15-B GeForce GTX 480 (Fermi) 1536MB 384-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card
oblisk July 18, 2010 05:05 AM
Thanks for the insight.
I live in Canada (Hardware canucks?!) and that newegg.ca doens't have the same deal :/
I'd like more insights from other users too.
kendallcschm July 18, 2010 07:44 AM
why not go for a 5970? although it is two GPUs.. it might be nicer.. but if you were to pick a card.. go for ATI.. they overclock nicely and i feel like you'll get more bang for your buck
fishingfanatic July 18, 2010 08:43 AM
Video Cards
If you're concerned about price or want a single gpu then get the 480. If not then +1 for the 5970.
:thumb::biggrin:
oblisk July 19, 2010 04:29 AM
Hmm, I think I am going to get a 480. Posted a WTB post too.
