Old July 16, 2010, 01:38 PM
Default 3 way sli or Sli and physics?
I have a evga 680i motherboard and 2 watercooled 8800 gtx ko acs edition cards in sli. A friend of mine is considering selling me his 8800 gtx card. Was curious what the benefit would be in either :
using all 3 in tri sli (having to buy a 3 way bridge) and i think all slots would bump down to 8x 8x 8x
or.. adding the card and still leaving the SLI enabled and using it s physics card (not using the tri bridge)
was curious what would be best? I am assuming its either or, unless i am completely of base here.
Frosty
i2600k sandy bridge @ 3.4ghz/ 2x 8800 GTX KO ACS3 PCI-E 630MHZ 768MB 2.0GHZ SLI'd / Raptor 74GB / Antec 1200 Hundred Gaming Case / G.Skill Ripjaws ddr3 1600 cl 8-8-8-24 - 8gigs / evga z68 SLI MOBO / Samsung DVD+RW / Corsair ax850 PSU / 24" Samsung CinkMaster
Cooling:
Swiftech Dual rad
Swiftech Single rad
Swiftech Micro Res
Swiftech Apogee GT Cpu block
Feser One Red Fluid
Old July 16, 2010, 01:43 PM
scruff's Avatar
I would start with the sli and use the other for Physx to start based on the response I got here and what I have read online . If you don't like the performance you can always add the tripple bridge later
Old July 16, 2010, 01:48 PM
Kommie986's Avatar
I think you should Tri-SLI. Not many popular games support PhysX (Other than Batman: AS and Metro).
Old July 16, 2010, 02:13 PM
with tri sli you wont see much of a performance boost in my opinion
Old July 16, 2010, 02:28 PM
, I see, this is mainly to cure a twitch that I am having inregards to tinkering with the computer, so basically im filling a void with this. MW2 is basically the only game I play at the moment. But i appreciate your thoughts on the subject. I just hope I can fit the darn card inbetween the 2 water cooled ones!!!! I may have to strip off the outer case.
if I get the card, I will mostlikely try both ways if the install isn't too painful!!!
thanks
frosty
Cooling:
Swiftech Dual rad
Swiftech Single rad
Swiftech Micro Res
Feser One Red Fluid
Old July 16, 2010, 02:46 PM
AkG's Avatar
AkG AkG is offline
Hardware Canucks Reviewer
Couple weeks ago I won a copy of MW2 (I would never pay for it...but free is free...only took me 6hrs to complete the single player on veteran though so it was "worth every penny" I paid for it :)~ ) I run it in 1920x1280 with the eye candy maxed out on a single 275 msi twin frozr.....and have never had a slow down that was noticeable. I truly DOUBT your 88's in SLI wont be enough horsepower. IF you want to go for the third....go for it, but I doubt you will gain anything from doing so. YMMV
Old July 16, 2010, 03:20 PM
bot worth it unless its free.
Old July 16, 2010, 04:52 PM
I ran fraps in preperation of the third card and used the bench mark feature during a MP game.... punched the f11 key a few times, basically in between deaths.... this is what i will compare it to , plus the 3dmark vantage score.
after all it is a hobby right!!!! :) Cant never seem to leave it alone!!!
Cooling:
Swiftech Dual rad
Swiftech Single rad
Swiftech Micro Res
Feser One Red Fluid
Old July 16, 2010, 10:10 PM
You would be better off selling both of your cards and upgrading to something from the current generation, honestly.
Old July 17, 2010, 04:53 AM
fishingfanatic's Avatar
Smile Video Cards
+1 for the new cards. I think a pair of 460s in sli will greatly outperform your setup and give you Dx11 capability. Otherwise I think sli with physics will be preferential. Let us know as now I'm curious about the results.
GTX 480: To SLI Or Not To SLI, That Is The Question? TheGregster76 Video Cards 22 June 15, 2010 05:47 PM
New Nvidia Drivers / SLI Multi Monitor + SLI on X58 - 180.48 probationer O/S's, Drivers & General Software 14 November 26, 2008 09:40 AM
Do I really need SLI ram in my SLI rig? Milt RAM 9 July 9, 2008 02:29 PM
Tri SLI, Quad SLI, SLI comparisons with 9800GTS, GX2 Babrbarossa Reviews & Articles from the Web 3 March 31, 2008 02:32 PM
