Old July 13, 2010, 07:39 PM
Default Need a budget video card
Hey , so the starcraft 2 beta just came back but now my poor old 6600 GT is not giving me playable frame rates at the lowest settings :( (without dropping resolution)
My budget is under $100 Canadian Ship , my PC is a pre-built so the power supply is < 300 Watts , if the card was phys-x compatible so that when I build a pc in september it is not a wasted investment. I would upgrade my PSU if needed but , I would rather not.
I Run 2 monitors at 1680 x 1050
I was looking at
NCIX.com - Buy ASUS GeForce GT 220 625MHZ 1GB 800MHZ DDR2 PCI-E VGA DVI HDMI HDCP Video Card - ENGT220/DI/1GD2(LP) In Canada.
NCIX.com - Buy ASUS GeForce 210 589MHZ 512MB 800MHZ DDR2 PCI-E VGA DVI HDMI HDCP Video Card - EN210/DI/512MD2(LP) In Canada.
or
Buy the Galaxy GeForce GT 220 1GB DDR2 PCIe, DVI/HDMI/VGA at TigerDirect.ca
Any help would be greatly appreciated!
Old July 13, 2010, 07:50 PM
Since they all have the same power requirements I'd definitively go for a GT240. However, with a generic 300W PSU, I am not sure how comfortable I'd feel.
XFX GT 240 512mb
MSI GT 240 1gb
I intentionally kept away from the DDR3 version because it is not quite as good.
Edit: Without PhysX, you've got an XFX 5570 for a pretty good price, in terms of performance it is comparable to the GT 240.
Old July 13, 2010, 08:55 PM
give us the p/n on the 300. ive upgraded a few dells with 9800gt's. can be had for cheaper than 240's
Old July 14, 2010, 11:55 AM
You would have to upgrade your PSU. The last time I ran a 300w psu in 2006 with a 1600xt my computer wouldn't start up again. Get at least 500w and a decent PSU.
Old July 14, 2010, 12:11 PM
You are wrong. 300W is plenty for a mid-range PC with a low-power video card like a GT 240.
Old July 14, 2010, 12:16 PM
CroSsFiRe2009's Avatar
GT 240 would be a good fit in your case. I ran a 8800GS which is almost the same thing with a 300W generic like yours for a year before I upgraded so it should definitely be fine
Old July 14, 2010, 06:59 PM
Turns out my power supply is only 245 watts , so I think I will upgrade my PSU and go with a GT 240 I will wait till payday and keep an eye open for deals though.
Thanks for all the help guys
Old July 14, 2010, 07:03 PM
Try to go for a DDR5 version of the GT 240, there seems to be a fair bit of difference between the ddr3 and ddr5 versions.
Old July 14, 2010, 07:28 PM
whats the part number on the psu? good manufacturers usually dont lie. if it holds 200 watts on the 12v you can put quite a couple cards in there
Old July 16, 2010, 07:55 AM
DPS-250AB-22 E REV 00 F
Is that the right code you were looking for?
Budget Folding Card Soultribunal HardwareCanucks F@H Team 19 April 8, 2009 08:46 AM
WTB: Video Card/Sound Card/Hard drive - Look here if u gotz some ! Flintblade Buy/Sell & Trade 4 December 4, 2008 09:27 PM
WTB PCI-E Video card with Video out Taichan Buy/Sell & Trade 0 June 9, 2008 08:17 PM
Budget video card advice needed please. Mumbly Video Cards 9 January 17, 2008 04:59 AM
Budget Video Card Selection BALISTX Video Cards 14 June 17, 2007 09:24 AM
