Clone or extended, doesn't matter. Only if you disable the second display, will clock speeds go down to idle. Pretty sure it is a known issue (if memory serves me correct). I can't say for sure, but I think my gtx 295 with dual monitors..did the same.
^^^ That is absolutely correct, with more than one monitor the GPU will not downclock, if the OP had of mentioned that he had two monitors hooked up to the GPU that would have twigged me and he would have saved the trouble of uninstalling / reinstalling Drivers......oh well, I believe nv is going to address this in an upcoming Driver release.
