Old July 7, 2010, 09:28 PM
Default ATI XFX 5850 pin connector help
Just put together a new rig and can't determine if i need a new power supply or not. I just bought the ATI XFx 5850 radeon card. And I'm using my old Antec 650 neopower power supply. I noticed my power supply only has 1 individual PCI express (6-pin) cable that can go on the vid card. However, the 5850 card has an extra slot for another PCI (6-pin) cable. From the manual it says "They are only designed to work with high performance power supplies using 6-pin PCI express power cable and it shows a nice diagram of the PS having 2 of the cables connected directly to the vidcard.
Do you guys think I need another power supply? I'm having other problems right now so I can't really tell if it works or not with only the one cable connected. However, I did see another way how I can get the other 6 pin connector to connect to the vid card, but the manual says it is very important to connect directly from the PS.
My previous vid card was a ati radeon 3870 and that only had one 6-pin connector slot which was perfect for my antec 650 PS.
What do you guys think?
Old July 7, 2010, 09:45 PM
Delavan's Avatar
I think that PSU will be OK....good thing it's a HD5850 and NOT a Fermi card!
I was running my HD5870 on a Antec truepower trio 650 watts (it had the 2 6-pins connectors tho)
You will have to use adapters (probably provided in the box) like a 2 X molex to 1 PCI-E 6 pin adapter.
both 6 pin PCI-E connectors on the card HAVE to be fed!!!
i7 4770K @ 4.0GHz / Corsair H100i / MSI Z97A Gaming 6 / 16GB Kingston Hyper X 1.5V 1600 / MSI GTX1070 FE / Samsung 850 Evo 500gb / Corsair Performance Pro 128GB SSD / Intel 520 120GB SSD / WD Black 640 GB storage / XFX 850 watts Black Edition PSU
Old July 7, 2010, 10:35 PM
yup. if not, i think i remember forgetting one, i think either it didnt go or couldnt do 3d. mems fuzzy about it.
Old July 8, 2010, 03:30 PM
Use one of the molex to PCI-E adapters that came with the card. It will be fine.
8 Pin 12V ATX Connector element291 Power Supplies 6 August 24, 2009 08:52 PM
[WTB] 2 PIN CONNECTOR FOR INVERTER BOX sinticfury Buy/Sell & Trade 10 June 27, 2009 11:08 AM
4 pin molex connector Phobia Off Topic 9 June 2, 2009 12:59 AM
Sleeving 24-pin ATX connector LC0g Guides & How-to's 19 May 19, 2009 06:18 AM
8-pin PCIe connector Dave510 Troubleshooting 13 April 24, 2009 07:54 PM
