View Poll Results: 5750 vs 5770 vs 5830 for gaming at 1680x1050
5750 1 2.44%
5770 30 73.17%
5830 10 24.39%
5670 (I might consider it if the above cards aren't necessary) 0 0%
Voters: 41. You may not vote on this poll
Old July 7, 2010, 10:08 PM
Delavan's Avatar
I'd say do everything you can to get a HD5850, it's gonna be better for the long haul...
i5 2500K @ 4.5GHz / NH-U12P / P8P67 DELUXE / 8GB Corsair Vengeance Arctic White 1.35V 1600 / 2 x N560GTX Ti Twin FROZR II OC in SLI (8823 3Dmarks11 P-score)/ Corsair Performance Pro 128GB SSD
Old July 7, 2010, 11:24 PM
FiveNines's Avatar
Originally Posted by jcmaz View Post
I would definitely get a 5770 for that res. Is it 1680 X 1050 res?
1280x1024 sadly. It was a 4 bill monitor back when I first purchased it in 2006.
I am a bit of a movie nerd and it has been a fight to not upgrade to something 1080p but if I plan on it I would like to know I can game at high quality at native res at the same time.
Thanks for the input
VCC Feedback
Old July 15, 2010, 12:16 PM
NaX's Avatar
NaX NaX is offline
can a 5750 oc'd reach the performance of a 5770?
that might be another option to consider
Old July 15, 2010, 12:20 PM
http://tpucdn.com/reviews/Powercolor...es/perf_oc.gif
perhaps.
Old July 15, 2010, 12:42 PM
Smoothie's Avatar
the 5830 isn't really worth it, for about $20-$30 more you can get a 5850 which destroys the 5830. Other wise I would get a 5770 if you are on a budget.
Old July 16, 2010, 08:05 AM
da 5770 is actually a very powerful card for the cost, without a doubt the best bang for buck card on market at the moment especiall for 1680 rez. Mine handles everything i throw at it w/ my tri core cpu, really dont need anything else (dont play or care for crysis, only demanding game out there for my 5770).
X6-1100T @ 3.8ghz w/ TT Frio @ 1400rpm @ 1.375v & 2.8ghz CPU/NB @ 1.35, 8GB Patriot DDR3 @ CL9-9-9-24, Gigabyte 970A UD3, Gigabyte Windforce OC GTX 670, Samsung P2770 @1080p, 64GB C-300 SSD & 2TB WD Black, X-FI gamer, Corsair HX520wt psu, Corsair 600T case, Win7 64
Old July 18, 2010, 03:59 AM
KnSKranky's Avatar
It can handle Crysis on Gamer settings quite nicely
i5 3350P @ 3.1ghz
8192mb DDR3 Corsair Vengeance
Gigabyte GTX 660 2gb
Windows 8 Standard
Gigabyte GA-B75M-HD3
1TB SATA III
Realtek Onboard
NZXT Phantom 410 Gaming Case
Corsair 500w
Old July 18, 2010, 04:23 AM
kendallcschm's Avatar
my 5770 got me good scores on 3Dmark06 and decent scores on 3d mark vantage
  #19 (permalink)
Old July 18, 2010, 05:13 AM
Personally I think your choice should be between the 5770 and 5850, the 5770 is an excellent card however the 128Bit Memory Bus could be a potential issue down the road. If at all possible I'd go 5850 just for that reason i.e. 256Bit Bus and future proof.
IMHO
Cheers; Snarl
Another Guy From Canada
  #20 (permalink)
Old July 19, 2010, 11:56 AM
Question
If OP is not NVIDIA hater, why not throw GTX460 1Gb or even 768MB (considering used resolution) to the Poll?
For less money then 5830 at that moment - it gives slightly better performance and amazing scaling in later SLI configuration.
Tags
5750 , 5770 , 5830 , ati , graphics
Upgrading videocard, 8800gt to 5770 or 5830? GameOnTurtle Video Cards 5 April 19, 2010 08:29 PM
5750 + 5770 In Crossfire ? CoolHandL Video Cards 2 April 13, 2010 02:17 PM
AMD Rumoured to Be Working on HD 5830 FiXT Press Releases & Tech News 14 January 31, 2010 04:47 PM
