Old July 3, 2010, 04:10 PM
fishingfanatic's Avatar
Smile Nvidia SLI question
Hi folks. I have a friend who has a reference 295 from EVGA and I have a reference from XFX. Both with the same memory and frequency capacities. I would like to try them in SLI just for benchmarking/performance curiosity. Any problems with trying this? Appreciate the help.
Old July 3, 2010, 04:16 PM
Soultribunal's Avatar
Does not matter who manufacturered the cards so long as their the same type. In this case obviously both are GTX295's so you shouldn't have a problem so long as your board is capable (and PSU lol!) of running quad-SLI.
ST
www.realhardwarereviews.com
Old July 3, 2010, 04:37 PM
SKYMTL's Avatar
HardwareCanuck Review Editor
Does yours have a centrally mounted fan? If so, there may be some compatibility problems with the original reference design cards.
Old July 3, 2010, 05:03 PM
someone back in the day mentioned about the single pcb with dual pcb's ones, but i havent followed up.
the connectors should lighn up, so unless the hs(as above) is modded/non reference/something special edition it should be ok.in theory.
Old July 3, 2010, 05:41 PM
Whether or not the connectors line up is not the factor that decides if SLI will work.
Old July 3, 2010, 08:17 PM
Arinoth's Avatar
Well all of these fit in your case, might want to make sure it'll fit wherever you put it
Here I am: here I remain
Old July 3, 2010, 08:20 PM
SKYMTL's Avatar
It has to do with the BIOSes in this case.
Old July 3, 2010, 08:32 PM
so driver checks bios, gets 295 check and then enables it. worst case scenario you should be able to flash either, but not recommended if its running fine. now if that one bios(on either board) is only for that board, then its a bed of nails awaiting
Old July 3, 2010, 11:19 PM
Smile Video Cards
Thanks guys. I couldn't see a reason for spontaneous combustion or sudden card launch, hehe. I'm currently running 2 5970s, so power should be ok, although if I'm not mistaken, the 295s actually draw more than them. Just curious about 3DMark results vs the others. I'm considering folding but understand Nvidia is much better. Can't imagine what some of those quad gpu systems will produce, but wouldn't mind seeing results from a test run of these either. If I can convince him to try it I'll let you know the results.
Old July 4, 2010, 02:48 PM
keep in mynd your motherboard must support SLI as well
GTX 480: To SLI Or Not To SLI, That Is The Question? TheGregster76 Video Cards 22 June 15, 2010 05:47 PM
NVIDIA Releases Their Own SLI Patch FiXT Press Releases & Tech News 0 July 8, 2009 01:30 PM
New Nvidia Drivers / SLI Multi Monitor + SLI on X58 - 180.48 probationer O/S's, Drivers & General Software 14 November 26, 2008 09:40 AM
NVIDIA nForce 650i SLI vs. nForce 680i SLI BALISTX Reviews & Articles from the Web 6 March 19, 2007 10:48 AM
OCers Online compares: Nvidia nForce 650i SLI vs. nForce 680i SLI Babrbarossa Reviews & Articles from the Web 0 February 28, 2007 11:54 AM
