Old June 29, 2010, 02:57 PM
bvsbutthd101's Avatar
Default Is my gtx 480 running hot
I just got my 480 yesterday and its idle is running at 60-63 c
and I have the fan at 80%
I one time it was running 47 c, that's what I want it at
My case is a coolermaster HAF 932 so I know there's plenty of ventilation
any reason for this?
Old June 29, 2010, 03:41 PM
they run hot.its 'normal'.shouldnt be but they do.
drop furmark and wait 5 minutes, see what temp it reaches. leave the fan on auto, then put it at 70%
Old June 29, 2010, 04:03 PM
I put the put the fan on auto and the temps are reaching 78 c idle now
Old June 29, 2010, 04:09 PM
belgolas's Avatar
Well it depends on the room temperatures. Run furmark and if it stays below 105c than it should be fine. If not than either get a replacement or replace the tim.
Sponsor a child!
Fight poverty.
Qoute by Perineum
"ID10T. I just BETCHA he's got 9 toolbars on his web browser right now."
Old June 29, 2010, 04:10 PM
Check to see nobody at the factory messed up the heatsink installation, if you don't feel comfortable taking off the shroud and taking the card apart contact EVGA.
Those temps are way off.
Old June 29, 2010, 04:12 PM
I thought the temps were off too, before the temps were idling at 47 c, I'll probably just call evga because I just got this and I don't want to break it the second day I have it.
Old June 29, 2010, 04:41 PM
r0bc's Avatar
I don't even need to have my fan speed set to 80% when I'm gaming and I'm using a 800d.
That seems hot.
Old June 29, 2010, 04:44 PM
unless the fan speed reported is different, theres no way its running hotter all of a sudden(idle or not) with same conditions as before(unless you checked with full blown ac on)
Old June 29, 2010, 04:53 PM
Well I just got off the phone with evga, they said the temps are not a problem because the card it meant to run that hot, and I have my computer down stairs and there's no A/C but now I have the fan speed on auto and the temps are reaching 78 c now
Old June 29, 2010, 05:17 PM
but seriously, furmark it some more. if it starts crapping out then worry.
lifetime is good.
Tags
480 , running hot , temperature , temps
Is my 5770 running hot? krajee Video Cards 6 June 23, 2010 01:17 PM
5850 running too hot? tragd Video Cards 10 June 7, 2010 09:31 AM
NVIDIA Clarifies Official GTX 480 and GTX 470 Launch Date matsta31 Press Releases & Tech News 76 March 9, 2010 02:07 AM
Q6700 running unusually hot? Connorreah Troubleshooting 6 August 2, 2009 06:21 PM
E6700 Running way too hot. r00tman CPU's and Motherboards 4 July 12, 2007 03:48 PM
