  #21 (permalink)
Old June 29, 2010, 09:29 PM
was thinking of the bfg thing(i.e. they can send you 8800/9800 gt's but dont have anything higher) so he will probably get an equivalent card
use everest as well for temp and stuff
  #22 (permalink)
Old June 30, 2010, 06:39 AM
bvsbutthd101's Avatar
I used everest too, but the temps are always different, like evga
precision is saying it's at 65 c right now and everest is saying it's
at 59 c, I don''t know which one is right
One thing I notice while in evga precision is that the card isn't under clocking itself
is it supposed to?
  #23 (permalink)
Old June 30, 2010, 01:57 PM
Dwayne's Avatar
Originally Posted by bvsbutthd101 View Post
I just got my 480 yesterday and its idle is running at 60-63 c
and I have the fan at 80%
I one time it was running 47 c, that's what I want it at
My case is a coolermaster HAF 932 so I know there's plenty of ventilation
any reason for this?
I have an EVGA GTX 480 and a HAF 922 case. My card idles at 40c, fan speed set to 60% and the house ambient temp is 23c. Are you using EVGA Precision to set the fan and check the temps? When I check Precision I see that my core is clocked way down to 51 MHz for browsing and such, when I play it clocks up to 700 MHz. Depending on the game the temps get up there, but not as drastic as some I have seen.
Mention the to the techs at EVGA that the card is not down clocking... or check the forums for similar problems.
Dwayne's Rig - Asus Prime Z370-A : i7 8700k : Corsair Vengeance 32 GB DDR4-3000 : Corsair RM650x PSU : Corsair H100i V2: Fractal Design Meshify C : EVGA GTX 1080 :
HTPC - GigaByte H67MA-UD2H : i3 2100 : 8 GB Mushkin Silverline Stiletto : Antec TruPower 550W : : Corsair H100 : Sapphire HD 6670 : Corsair 650D: Kingston 60 GB SSD Boot
Tablet - Samsung Tab A 10.1"
Wife's Rig - MSI GL72M 7RDX
  #24 (permalink)
Old June 30, 2010, 02:41 PM
Yea the card isn't downclocking, when I check it in precision the core clock is at 700, some times it goes down to 400 but it just goes right back up to 700. The shaders and memory stay the same also.
  #25 (permalink)
Old June 30, 2010, 02:44 PM
Digikid's Avatar
Its a 4xx series GeForce.....they are hot enough to cook breakfast on. LOL!!!
You can always watercool it.
  #26 (permalink)
Old June 30, 2010, 02:52 PM
yea they do get hot, I touched the pipes on the card and burnt myself
  #27 (permalink)
Old June 30, 2010, 03:03 PM
If your card isn't underclocking properly, try cleaning your drivers and reinstalling them. Shouldn't be the sole reason for your temps though.
I have a GTX470 that idles at 38c (it's got better cooling than the 480) and my room temp is 27-28c.
You shouldn't get nearly double my temps at a lower room temp, with potentially better airflow.
  #28 (permalink)
Old June 30, 2010, 03:34 PM
LionRed's Avatar
If running dual monitors, temp will get into the 80's during idle.
They say you can tell how rich a man's life has been, by how many dogs he has had in it.
RIP Kiwi - Oct 19th/05 - April 18th/11, you will always be our puppy!
  #29 (permalink)
Old June 30, 2010, 04:47 PM
belgolas's Avatar
Well idle temps are not the greatest concern. You already mentioned that at load you only get 92c. I wish mine never went pass 92c. Mine easily hit 105c when I am at a lan with my friends all cooking in the same room. So if your cards stay below 92c then to me you have a cool running card. Nothing to worry about. If it bothers you than replace the tim.
Sponsor a child!
Fight poverty.
Qoute by Perineum
"ID10T. I just BETCHA he's got 9 toolbars on his web browser right now."
  #30 (permalink)
Old June 30, 2010, 06:49 PM
LionRed's Avatar
I think mine hit around 95C under 100% load...idk what fan speed is. Does it really matter....these cards run toasty. Lol toasty enough that I burned my finger on one of the cards (blister and all)...and this was a couple minutes after it was benched. Room temp in shop is hitting 29C....while gaming (luckily..computer desk is in adjacent room). If guys can run these cards in tropical latitudes...then we do not have much to worry about in Canada.
Tags
480 , running hot , temperature , temps
Is my 5770 running hot? krajee Video Cards 6 June 23, 2010 01:17 PM
5850 running too hot? tragd Video Cards 10 June 7, 2010 09:31 AM
NVIDIA Clarifies Official GTX 480 and GTX 470 Launch Date matsta31 Press Releases & Tech News 76 March 9, 2010 02:07 AM
Q6700 running unusually hot? Connorreah Troubleshooting 6 August 2, 2009 06:21 PM
E6700 Running way too hot. r00tman CPU's and Motherboards 4 July 12, 2007 03:48 PM
