Originally Posted by Arinoth Well what is there rest of your system? Are you looking to run them in say a surround setup? If so you need a 5870 or higher from ATI and the current 4xx series from Nvidia to do this. |
I have atm a P5Q pro, Q9550, 4g ram, 8800GTX, 36g raptor os drive with 500g black storage.
My plan is to use these for gaming of course. depending on the game (BC2 ect) run right across all 3 or with say Guild Wars use 1 monitor for each account i'm using at once.
Originally Posted by _dangtx_ just for display? you gtx can run 2, add either a low power pci or pci-e ati or nv. if you have a spare slot. theres also those video splitting thingies, take one exit and goes to a few monitors. the good ones are expensive tough |
Yeah i'm running dual CRTs atm but have a chance to buy 3 LCDs. If I can get away with adding a 2nd PCIe card as my board can run crossfire setup so 2 PCIe slots are available right. What card would be best suited? There are a few cheaper 8800s on kijiji that I can pick 1 up of also?
