Old June 27, 2010, 01:49 PM
Default 2x HD5850 CROSSFIRE or ATI Radeon 5970 2GB GDDR5 Ram
What of these setups will have the highest preformance and a better future?
ATI Radeon 5970, 2GB GDDR5 Ram
or
2x HD5850 in CROSSFIRE
If you have anything at all to say, be very kind to do so
Old June 27, 2010, 01:56 PM
if your mobo takes 2 pvi-e videocards, perhaps go that route. or one 5850 now and see if you need more power later? :)
Old June 27, 2010, 02:29 PM
A 5970 is faster. Same clock speed but more shaders. Of course, two 5870s in Crossfire would provide even more performance.
Old June 27, 2010, 04:06 PM
fishingfanatic's Avatar
Smile Video Cards
If you think you may go to crossfire in the not too distant future and can/are willing to spend the extra, 2 5870s are better than a 5970. That said, the one card takes up less space and uses less power, if I remember correctly. There is also less heat. I have the 5970 Black from XFX and love it. When you get up that high, a few frames/sec probably won't be noticeable. I don'r recall how the 5850 compares, but there are a few reviews that should list results comparing those various cards as singles and in crossfire. Good luck with your choice and enjoy!
Old June 27, 2010, 04:14 PM
and if memory doesnt fail me the 5970 is a dual 5850 ahem.
Old June 27, 2010, 05:24 PM
lowfat's Avatar
It is a dual 5870 w/ slightly lower clocks. Although the HD5970 can generally pass HD5870 clocks w/ ease.
Old June 27, 2010, 05:25 PM
Correct. The 5970 has less components than a pair of 5870s have, and the GPUs are also clocked lower so they consume less power as well.
The 5970 is a dual 5870 with the GPUs set to the same clock speed as the 5850.
Old June 28, 2010, 12:31 AM
your better off with 1 card
i dont regret my 5970
i regret my 5870 cards
maximus IV extreme @ 5.1 1.41v
evga e760 +920 4.8 water5.0+ on phase linx stable
gtx285 tri-sli
dfi ut-p35 lt
e8600@4.6 1.38v
too much ram
Old June 28, 2010, 02:50 AM
Thanks for all the good replies.
I am just checking the alternatives :)
Maybe in the future i could go 2x 5970 ;)
Old June 28, 2010, 04:10 AM
Delavan's Avatar
Plz elaborate!
i5 2500K @ 4.5GHz / NH-U12P / P8P67 DELUXE / 8GB Corsair Vengeance Arctic White 1.35V 1600 / 2 x N560GTX Ti Twin FROZR II OC in SLI (8823 3Dmarks11 P-score)/ Corsair Performance Pro 128GB SSD
[FS] FS: ATI 5970 2gb oem MarcusFoX Buy/Sell & Trade 11 December 4, 2009 06:38 PM
Hold on ATI...nVidia 2GB 55nm GDDR5 ? rjbarker Video Cards 1 September 24, 2008 04:48 AM
Qimonda Bringing GDDR5 to ATI's Radeon 4000-series Hardware Canucks Press Releases & Tech News 1 May 26, 2008 07:44 PM
