Old June 26, 2010, 06:16 PM
OmegaRED's Avatar
Default Got a 5870 Vapor-X, should I bother to keep GTX for Physx?
I replaced my BFG GTX 285 2GB with a Sapphire 5870 Vapor-X. I wanted something faster but mostly it was the better cooling and silence which motivated the switch.
Should I just sell my GTX 285 or swap it with a family member for a 8800GT and use that for Physx? I am willing to put up with the extra noise and heat of two GPU's provided it will actually be of some benefit. Aside from Batman and the Ghost Recon games I don't know of any big Physx games on the horizon. Opinions?
E-Penis Specs:
Coolermaster Cosmos II \\ Intel i5 2500K@4.8ghz \\ Gigabyte PA67 UD7\\ MSI Twin Frozr GTX 680 SLI \\Corsair Vengeance 8GB LP \\ Seasonic Platinum 1000W \\ X-Fi Titanium HD \\ OCZ Vertez 3 120GB \\ RAID 0 Seagate Barracuda 1TB SATA6G 64MB \\ Samsung 27" 3D LED Monitor \\ Logitech G5 \\ Logitech G-15 Keyboard \\ Logitech Z-5500 \\ Sennheiser 595 \\ Windows 7 x64
Old June 26, 2010, 06:32 PM
hmm...if physx is important, keep it. else,sell it. fast ;)
Old June 26, 2010, 08:05 PM
Delavan's Avatar
BFG is getting out of the videocard business...if that card ends up dying down the road, you "might" have an issue getting it replaced...I would get rid of it!
If you really want PhysX, some people here could propose some less expensive and less power hungry cards that would be good enough for physX... I wouldn't bother tho...
i5 2500K @ 4.5GHz / NH-U12P / P8P67 DELUXE / 8GB Corsair Vengeance Arctic White 1.35V 1600 / 2 x N560GTX Ti Twin FROZR II OC in SLI (8823 3Dmarks11 P-score)/ Corsair Performance Pro 128GB SSD
Old June 26, 2010, 08:18 PM
they will replace it, but will they do it with an equivalent card? dont think they have stock left..by now.
Old June 26, 2010, 08:51 PM
If you really want PhysX support then I would say go with a cheaper GPU and sell off the GTX 285. I don't see much point in keeping it unless you're a folder.
Old June 26, 2010, 09:36 PM
OmegaRED's Avatar
Ya, Physx isn't a big thing for me anymore, otherwise I wouldn't have gone with an ATI card. Only way I'd keep it is if someone could suggest a few titles that demand Physx. I'll sell it
E-Penis Specs:
Old June 28, 2010, 03:51 PM
Good choice - get rid of it.
Old June 28, 2010, 07:41 PM
rjbarker's Avatar
you purchased an ATI Card cause you wanted less power hungry and heat.....so why would you want to keep it in your system for a few games??? I really don't get mix n matching nv / ATI for PhysX enabled games.....if those games are so important stick to nv......other wise get rid of it.....can't imagine the "Driver Headaches" this would involve...not worth it imo.....
Classified Ultra SLi "Procyon"
http://i30.photobucket.com/albums/c3...2/DSC02888.jpg
http://i30.photobucket.com/albums/c3...2/DSC02889.jpg
Evga 4.2 Ghz Club....
Old June 28, 2010, 09:04 PM
lowfat's Avatar
If you don't fold there is no point in keeping it. The power consumption versus the rare game that supports PhysX is not worth it.
5870 Vapor or EVGA 470+ and warranty question FreeKnight Video Cards 6 May 28, 2010 10:15 AM
Can't Get 5870 Vapor-X Passed 900MHz Uberg33k Overclocking, Tweaking and Benchmarking 5 April 4, 2010 10:24 PM
Dedicated PhysX... Shall i bother ? JORD4N Video Cards 11 November 1, 2009 05:50 PM
Sapphire reveals the HD 5870 Vapor-X Gav Press Releases & Tech News 7 October 27, 2009 11:50 AM
