Old November 21, 2007, 03:19 PM
donimo's Avatar
Default So why don't I have Overdrive availible?
I have 3 ATI cards, and have NEVER had the Overdrive tab availible, EVER.
9600
x800 XL
1950pro
Any reason for that?
Any way to "unlock" it?
I can't find squat online about this for some reason...
Mobo GA-Z77X-UD3 CPU i5-3570K stock RAM:2x4GB Patriot Viper 1866 1.5v GPU:XFX HD6850 BE + Gigabyte HD6850 @820/4400MHz Case:Bitfenix Raider w/2x 200mm + 135mm PSU: Corsair HX620
Old November 21, 2007, 03:23 PM
SKYMTL's Avatar
HardwareCanuck Review Editor
In these cases it is best to use a program like ATItool or Rivatuner.
Old November 21, 2007, 03:24 PM
donimo's Avatar
Oh, I do, for sure.
just find it weird, what are it's criteria for who gets to use it?
Old November 21, 2007, 03:51 PM
SKYMTL's Avatar
To tell you the truth I never use the overclocking software provided my ATI or Nvidia. I have always used third party apps like ATItool or RT so I really chouldn't tell you.
Old November 21, 2007, 06:21 PM
Amon's Avatar
Overdrive shows up for my (awesomely mighty) 9600 SE 128MB if I have the entire software suite installed, which, if I remember correctly, requires a newer .NET framework.
Old November 22, 2007, 12:54 PM
donimo's Avatar
well, I just did a wipe and fress install of the drivers/catalyst for the new 7.11 drivers, still no overdrive...
whatever, stupid 1950pro wont overclock the memory anyways.
why won't it let me even bump it 1 mhz?
gpu goes from 575 to 650 no problem, mem wont budge an inch, just locks up everything
Old November 26, 2007, 02:01 PM
same thing happens to me when trying to OC my 2900xt using ATI Overdrive... haven't figured out the problem
Old November 26, 2007, 07:14 PM
sswilson's Avatar
Strange that you don't have the "unlock" button on the overdrive page... works fine with my 1950pro.
Do you have .net 2.whatever installed?
As far as the mem goes.... yeah, the mem used on the 1950pro models was already pretty well maxed out as shipped.
Old November 26, 2007, 07:32 PM
donimo's Avatar
I don't even have an overdrive page, nothing, last tab is Avivo video...
.net 3.5 actually tried that already, no go, darn it all to heck
Old November 26, 2007, 07:37 PM
sswilson's Avatar
Hmmmmm you don't even have the vpu recover????
That truly is bizaare!!!!
Not sure what to ask other than if you're sure you've got the full catylist installed instead of just the drivers.........
Problem with AMD OverDrive xtreme1 CPU's and Motherboards 3 March 10, 2008 01:24 PM
